I need a new radio in my CJ - Page 2 - JeepForum.com
post #16 of 21 Old 06-11-2012, 07:19 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's what I stuck in mine....it cranks way louder than I'll ever listen to it, and I love the auxiliary feature.
Retrosound radio
Infinity Kappa 6x9 rear speaks
Bazooka 5-1/4" front speaks
Rockford 300W ultra-compact 4-way amp (in Tuffy center console)
Matt
Matt1981CJ7 is online now
post #17 of 21 Old 06-11-2012, 08:21 AM
bkeese
1949 CJ3A
Check the Total Harmonic Destortion (THD) rating. Most radios are 5% and thats too high (destortion over half volume). Try to fine one under 1%, you'll hear the difference, because driving a noisey topless Jeep the volume is always over half.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #18 of 21 Old 06-11-2012, 09:38 AM
robertvich
Retrosound radio
Matt
Looks good Matt! I'm thinking of mounting my amp in my Tuffy console as well. Which size Tuffy do you have? I have the 10". Would you be able to post a pic of the inside where you mounted the amp? Did you have to make any larger hole to run the RCA, power, ground and speaker wires?
Thanks!
Robert
robertvich is offline
post #19 of 21 Old 06-11-2012, 09:52 AM
Matt1981CJ7
1981 CJ7
Robert,
Thanks. I have the 10" Tuffy, as well. As you can see, there's plenty of room for the Rockford amp.
Don't let the small size fool you, however. That little amp packs a punch.
Yes, I drilled an additional hole in the bottom of my Tuffy to run the wires. In hindsight, I should have mounted it farther forward, towards the front, because the controls are a little difficult to get to.
Hope this helps,
Matt
post #20 of 21 Old 06-11-2012, 09:58 AM
chrisooneal
1981 CJ5
Originally Posted by g00fy1 View Post
I like these: http://www.ebay.com/itm/1978-1986-Je...ht_2415wt_1318
When it's off, it looks like an old dial radio, when it's on it shows an LCD screen. Mine has been cut to a single DIN so this won't work for mine.
It even says "Jeep" on it.
That's the one I have. LOVE it.
chrisooneal is offline
post #21 of 21 Old 06-11-2012, 11:49 AM
JMcDonaldKnives
1980 CJ7
Heres an option if you want a marine unit. It looks to be pretty decent and has everything you want.
http://www.basspro.com/Kenwood%C2%AE...1130915/366069
JMcDonaldKnives is offline
cj7 , radio
AM / FM Stereo radio conversation to AM /FM / CB radio / wiring questions GlennLever Jeep CJ Forum 11 07-14-2015 08:22 PM
CJ Radio collinpyle Jeep CJ Forum 4 05-16-2006 12:12 AM
CJ Radio collinpyle Jeep CJ Forum 8 05-12-2006 10:07 PM
AM Radio My77cj5 Jeep CJ Forum 3 02-19-2005 08:34 PM
cb radio - which one? certifiablejeep Jeep CJ Forum 3 12-20-2004 02:03 AM
