I love my "The Club" - Anti Theft Device - Page 3 - JeepForum.com
post #31 of 39 Old 07-30-2013, 08:53 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Originally Posted by LeePrather View Post
Transfer case in neutral, not transmission
If the transfer case is in neutral, "Park" on the transmission is nullified.
Nobody should ever park any car with just the brake holding it....it's called the Emergency brake for a reason. Manuals should always be in First or Reverse with the brake on, and automatics obviously should be in park.
Leaving the transfer case in neutral is effectively the same as leaving the transmission in neutral....in that the vehicle will still roll.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #32 of 39 Old 07-30-2013, 11:44 AM
Renegade82
1982 CJ7
I fully agree. I'm always amazed at the amount of people I see that just slip her into neutral and push or pull on the ebrake.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #33 of 39 Old 07-30-2013, 02:28 PM
LumpyGrits
Originally Posted by Truck633 View Post
I don't smoke anymore, so I figured the ol' ground through the cigarette lighter was my best option. Just pull the lighter out far enough to break contact, It will drive anybody crazy!! Let them try and try to start it, then once they are furious, simply push ciggy lighter in, make connection for the ground and presto!!
Not a contact I would trust on a bad road etc.
LG
LumpyGrits is offline
post #34 of 39 Old 07-30-2013, 03:22 PM
Jim1611
Jim1611's Avatar
Put a twin stick shifter in for the transfer case. Then leave one axle in 4low and the other in 4high. Make the shifter levers so they can easily be taken off and when someone tries to drive away they'll keep killing the engine. Down side is that they could tear the something up but at least the Jeep stays.
Jim1611 is offline
post #35 of 39 Old 07-30-2013, 03:40 PM
LumpyGrits
LG
post #36 of 39 Old 07-30-2013, 08:22 PM
jeepwhore
Originally Posted by Joe6Pack74
Theft is something I have been worrying about. Has anyone used a quick release steering wheel disconnect? I would think a thief would pass up a vehicle without a steering wheel.
As mentioned, I have one. It moves the steering wheel about 3" closer to the driver so if you're more, ummmmm.........robust, it may make it a tighter squeeze to get behind the wheel.
But I love it.... Especially since my steering lock is no longer functional. It's some good piece of mind knowing it can't be driven or even rolled out of the driveway easily. If somebody wants it they'll have to tow it away.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #37 of 39 Old 07-31-2013, 12:05 AM
rixcj
rixcj's Avatar
1979 CJ5
Years ago, back in the '80's I made a rectangular collar clamp out of 1/4" thick stainless steel. It hinged open and closed, and fit snugly around the brake and clutch pedal arms. I had a padlock that I challenged any friend of mine who could pick locks to pick it. No one could.
It also had a stainless post welded to it, coming off of the bottom of the collar that reached down and hit the floor.
This way, the pedals were locked together, and couldn't be pushed down, at all. Stainless takes a while to cut through with a saw, and cannot be cut with a torch.
It only took a few seconds to put it on, or to take it off.
Not a perfect solution, but it'll definitely slow down a thief, who'll hopefully move on.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #38 of 39 Old 07-31-2013, 12:29 AM
jtstj
jtstj's Avatar
When I purchased my CJ, the PO had a large padlock where he would lock the clutch and break together. Pretty effective IMO, I guess the quality of the lock would make a difference too.
jtstj is offline
post #39 of 39 Old 07-31-2013, 12:45 AM
Joe6Pack74
Thanks don't know how I missed the earlier post. Always wanted one when I was doing the circle track racing. But it was not allowed in the "bomber" class or "enduro" races.
Joe6Pack74 is offline
anti-theift , cj , cj7 , stolen , the club
