I know some of you will *****! custom CJ half doors - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I know some of you will *****! custom CJ half doors
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK
Unread 05-18-2015, 03:42 PM   #1
pirateBob64
I had this pair turd brown CJ full Metal doors. They were not in the best of shape and I have the original red factory doors in my shop. Anyhow I hate how the TJ doors look on the CJ and feel if AMC would have made factory half doors they would have looked like I made them. The design a lower me to put the aftermarket latch in upside-down wich made them a pop down button. I still have a quite a bit of work but you can see how they look. Up where the vent window was I will cut and install a 3" cup holder which will be half way inset.
I know holy crap he cut up full Metal doors, I have door glass and two fixed glass vent glass for sale make me an offer and pay shipping. Vent glass will have gaskets with them.
pirateBob64 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 03:59 PM   #2
lovett86
I like em
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 04:08 PM   #3
Mortgage-payer
1976 CJ7
That pointy edge will do a lot of damage to you in an accident.
I call it a distributor, not a dizzy.
Mortgage-payer is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 05:02 PM   #4
jeep_boy02
1980 CJ7
Not too shabby, I may have to do something like this as I have a couple extra doors too.
jeep_boy02 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 05:54 PM   #5
pirateBob64
your concerned about sharp edges and you drive one of the most unsafe vehicles to be in if hit from the side or rear or front!
Unread 05-18-2015, 06:11 PM   #6
CSP
No need to make it worse.
CSP is online now   Reply With Quote Quick reply to this message
Unread 05-18-2015, 08:31 PM   #7
Mortgage-payer
1976 CJ7
I drive carefully.
Unread 05-18-2015, 09:08 PM   #8
streetpro
1978 CJ7
Originally Posted by Mortgage-payer View Post
I drive carefully.
Nobody else does, and that's why you should knock that corner down.
I've seen some things...
streetpro is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 09:33 PM   #9
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Nasty looking, I sure wouldn't want that top corner....
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 11:33 PM   #10
RWC
AMC designed the YJ half-doors.
RWC is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 07:27 AM   #11
Pathkiller
1974 CJ5
According to what data? I've actually been in a substantial side impact collision in a CJ that sent the other driver to the hospital and totaled his Nissan Maxima. I literally drove the CJ home and didn't even have a bruise.
The "unsafe" reputation of a CJ is not supported by real data.
74 CJ5 complete frame off restoration
Pathkiller is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:06 AM   #12
holliewood61
holliewood61's Avatar
1981 CJ7
Im in the process of doing the same thing. I snagged a set of full doors that someone had cut on the inside for some reason to get the glass out, so I didnt feel bad about some more cutting. Mine had the rotary latches rather than the paddle, so I did away with the exterior latch. I had to cut out and lower the interior latch. I followed the taper of the top hinge, rolled off the corner of the hinge in a straight line to the body line, then straight along the body line to the back of the door.
Edit with pics:
Heres how im doing mine.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:44 AM   #13
John Strenk
John Strenk's Avatar
1976 CJ5
I kinda like it,
Nothing on the CJ is so 'pointy' so I would cut that sharp corner down with a radius to match the two bottom corners.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 10:38 AM   #14
jleblanc31
1979 CJ7
I like it got to find me some cheep doors now.
jleblanc31 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 12:16 PM   #15
pirateBob64
why they look pointy
If you look at factory doors the body line that runs down behind the vent window and radiuses back that is the factory bodyline I used to cut The shape. when it's uncut on a full door it does not look pointy but it is. Plus the height of the body line is exactly perfect height to rest my arm.also not cutting down allows me to 6x9 speakers in the large rear retangle shaped opening and a possible pocket in the forward square opening and then covering with Diamond plate with drilled out 1/4"holes where the speaker will be. I am trying to work out how to make the top button blend in with the top ,I am thinking of making a 1" square you will push down to open. Quick release plugs on the speaker wire. And of course the cup holders like I mentioned in the original post.
