I just bought a CJ-5 (I think) - JeepForum.com
post #1 of 23 Old 04-16-2006, 11:00 PM Thread Starter
Tyork_tex
Hi, I have a 89' jeep cherokee and I have posted in that forum several times, but today I purchased for $1000.00 what I think is a CJ-5 and drove it with no windshield, no top, no doors, a sticking throttle pedal, lots of smoke and lousy brakes the 20 miles back to my dads farm and will go pick it up next weekend. (What an adventure that was )
The reason I am unsure of the model is that it has no tailgate, were CJ-5 offered without tailgates or did someone just weld mine up (there are no indications of this)? I also don't know the model year. Either way, I do know that it has a four cylinder gas (Hurricane?) engine, a three speed transmission (T-90?), a front/rear passenger side offset, twin stick, transfer case (dana 18?), and offset axles. My guess, just from the little research i have done,would say that the front was either a D25 or D27 axle and the rear a D44. but i have no way to confirm any of this.
I have a ton more questions but I'll save those for another thread. Any help identifying this Heep and any of the other parts on it would be greatly appreciated.
Tyork_tex is offline
post #2 of 23 Old 04-17-2006, 05:27 AM
Curt Reinhardt
1978 CJ5
I have a 1978 CJ5 without a tailgate.
Curt Reinhardt is offline
post #3 of 23 Old 04-17-2006, 06:19 AM
MeCasa
I run a 77 CJ7, but I also have a 78 CJ5 without a tailgate
AMC special
Sex is dirty only if it's done right .... Live and Let Live .... Rules are Boring and I Don't Like Them
................................................ MeCasaEsSuCasa .................................
MeCasa is offline
post #4 of 23 Old 04-17-2006, 06:53 AM
dvbum
1982 CJ5
I have a 82 CJ5 no tailgate.
Best of luck in rebuilting your CJ5!!
dvbum is offline
post #5 of 23 Old 04-17-2006, 09:26 AM
mr_frenchy
If you can get me the VIN #, could tell you what it is .
Some CJ's have tailgates, some don't, I believe it was an "option" at that time...
'75 CJ5, SOA, 36" buckshots, Warn 9000i upfront, 304 V8
In the Bible some where it says that if you sell your Jeep to buy a honda, you'll go to hell. It's somewhere in the back, near the maps.
mr_frenchy is offline
post #6 of 23 Old 04-17-2006, 11:14 AM
jakemary
1977 CJ7
what is the wheel base?? the cj 5 is 14"shorter than the cj 7 . and the doors are different.
jakemary is offline
post #7 of 23 Old 04-17-2006, 12:52 PM
COBRA5LADDICT
10" Shorter
COBRA5LADDICT is offline
post #8 of 23 Old 04-17-2006, 01:16 PM
1979CJ7
1979CJ7's Avatar
1979 CJ7
the body should have some sort of "lip" sticking out. the doors are not perfectly straight like the newer jeeps. they have a stupid little piece sticking out. i dont have any pictures ATM but i will see what i can do. i am sure someone will have pictures of a 5 and 7 to show you.
1979CJ7 is offline
post #9 of 23 Old 04-17-2006, 02:03 PM
CT CJ
2009 JK Wrangler
a CJ 5 door frame will look like the back door on a cherokee... (on the cherokee, its the wheel well hump, on the CJ they cut the body in that way...)
the CJ7 will have a door similar to the wrangler (of any year)
i've seen a number of CJ's both 5's and 7's that didn't have a tailgate... they did a solid tub in the late 70's for some odd reason...
CT CJ is offline
post #10 of 23 Old 04-17-2006, 02:06 PM
1979CJ7
1979CJ7's Avatar
1979 CJ7
thats the description i was wanting to say heh couldnt think of it
1979CJ7 is offline
post #11 of 23 Old 04-17-2006, 05:02 PM Thread Starter
Tyork_tex
Do you know where the vin# is located on it?
post #12 of 23 Old 04-17-2006, 05:26 PM
Heepajeep
Sounds like a 1955 to 1971 CJ5 which is 12.5" shorter wheelbase than a CJ7.
Where is the gas tank?
Heepajeep is offline
post #13 of 23 Old 04-17-2006, 05:29 PM Thread Starter
Tyork_tex
It is under the driver seat.
post #14 of 23 Old 04-17-2006, 06:24 PM Thread Starter
Tyork_tex
It has S-shaped door frames (the best way i can explain it) instead of the u-shaped door frames like the Cj-7 and Yj/Tj wranglers. So it is probably a Cj-5 but I 'm not sure the year model were is the vin # at?
post #15 of 23 Old 04-17-2006, 07:36 PM
No_Bs
1977 CJ5
Its a 5 then, the vin should be on the drivers side firewall.
No_Bs is offline
Bought my first CJ7, need some help KaosInc Jeep CJ Forum 15 03-08-2009 12:16 PM
So I bought an -----HEI------ instead of a DUI T-$$ Jeep CJ Forum 29 04-12-2007 11:26 AM
Just bought a '83 CJ 7 and need some help sgt jeep Jeep CJ Forum 5 04-07-2007 11:37 AM
Bought a CJ tubbieterror Jeep CJ Forum 6 08-03-2004 09:10 PM
Just bought a 75 Cj 5 Silver yj Jeep CJ Forum 8 02-24-2004 08:30 PM
