I have the T-18A Whats next - JeepForum.com
post #1 of 11 Old 08-13-2003, 07:47 PM Thread Starter
Steve Ingram
I Have come across a T-18A. I have a 79 CJ5 all Stock, The T-18 A came out of a 78 Ford Two Wheel drive.
I need to now how and what i need to put this in my jeep.
I am also thinking of going with a dana 300 and not using the 20 thats in it.
I know someone will help me out. Thanks
Steve Ingram is offline
post #2 of 11 Old 08-14-2003, 07:23 AM
cjryder
Hi Steve, I have a mid 70's Ford T18A and a 75 cj5.
I haven't done the swap yet so I'll be watching this thread.
So far, what I gathered is;
The T18 needs the T150 bell housing, a longer front drive shaft, shorter rear drive shaft and an adapter to the t-case.
(Advanced adapters, around 400 bucks).
I think the pilot shaft needs swapping out as well, and I think that's available with the adapter as a kit.
There is good info at their website and at jeeptech.com
75 cj5 , 51 m38
"the wife asks 'why 2 jeeps?', I tell her that's all I could find so far"
cjryder is offline
post #3 of 11 Old 08-14-2003, 08:22 AM
lynn
lynn's Avatar
Here's that link:
http://www.off-road.com/jeep/tech/convtrans/fordt18/
Lynn
'05 LJ
lynn is offline
post #4 of 11 Old 08-14-2003, 02:05 PM
Bulletproofcj7
Originally Posted by lynn
http://www.off-road.com/jeep/tech/co...s/convt18.html
http://www.offroaders.com/info/tech-...18-rebuild.htm
http://www.novak-adapt.com/
Here are a few sites I came across while considering that conversion that may or may not help.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #5 of 11 Old 08-14-2003, 05:41 PM
MuddyWaters
"The T18 needs the T150 bell housing"
Or you can get extremely lucky and find the original bellhousing made for the T-18a to go with the jeep. Better yet, find the original T-18a from a CJ-5 (with the Dana 300 Transfer!) and buy the whole thing for $1100. And it has alloy wheels and new Kumho MTs!
Ok sorry I'm still bragging over that lucky find....If you have the tranny out, I am assuming you do, figure out which ratio first gear is. Some have the 6.32:1 granny gear. Others have a 4 somthing (i think):1 1st gear. there was a thread a while back about this and what it takes to convert the T18a to the 6.32:1 first gear ratio, if desired.
79 CJ 5
T-18a
258 with some goodies
3 Year Custom Rebuild coming to an end. Website soon.
MuddyWaters is offline
post #6 of 11 Old 08-14-2003, 05:53 PM
jeffs77CJ5
jeffs77CJ5's Avatar
I am having my current T-150 replaced with a T-18a on Monday. The T-18a came out of a 77 CJ5 with a I6. It is going into a 77 CJ5 with a 304. I have everything to replace the T-18a tranny with (ie. yokes, driveshafts, skid plate. The T-18a will match up to the 304, Correct? I even have the four spacers for the skid plate. Both have Dana 20's. Is that all I need for the swap?
jeffs77CJ5 is offline
post #7 of 11 Old 08-14-2003, 07:39 PM
CSP
Jeff you have what you need. The T18 bolts up to the bellhousing, not the engine. The bellhousing to engine bolt patterns on the V8 and I6 are the same.
CSP is offline
post #8 of 11 Old 08-14-2003, 07:41 PM
CSP
You had better check out that transfer case if the tranny truly was an original CJ tranny. The Jeep T18 will not bolt up to the Dana 300. You either have a Fod T18 converted to work with a Dana 300 or a Dana 20 transfer case.
CSP is offline
post #9 of 11 Old 08-14-2003, 09:46 PM
jeffs77CJ5
jeffs77CJ5's Avatar
Thanks CSP!!!!
post #10 of 11 Old 08-15-2003, 11:37 AM
Incredable
hey i have a 79 CJ-5 with the T-18a and i love it. Did off roading for first time and the thing handled like a champ. I was going place a H1 couldnt go.
79 CJ-5 (Fair amount of goodies)
Blue jeep club #24
Incredable is offline
post #11 of 11 Old 08-15-2003, 04:36 PM
MuddyWaters
It has an adaptor
79 CJ 5
T-18a
AMC 258 I6 - Whats your MPG??? shok47 Jeep CJ Forum 40 09-09-2014 12:50 PM
Whats is my mpg? shok47 Jeep CJ Forum 8 06-14-2009 02:47 PM
Whats this fer?? thich Jeep CJ Forum 14 04-06-2008 06:25 AM
Whats Your Next Mod? tmak504 Jeep CJ Forum 15 03-01-2006 12:23 PM
Got the body off!! whats whats? humboldt_jeep Jeep CJ Forum 11 05-06-2004 04:37 AM
