I have to replace my Windshield cowl and glass seal. - JeepForum.com
post #1 of 15 Old 10-20-2013, 01:34 PM Thread Starter
wsmutch
I knew the windshield on my 1986 CJ-7 was leaking a little, and could see the windshield cowl seal was dried out and cracked and probably part of the problem. It was so bad it wrecked a new radio. Before I replace the radio I need to replace both, but I want quality parts, as I have heard that there are some issues with fit and quality. What are your best experiences? I only want to do this once.
wsmutch is offline
post #2 of 15 Old 10-20-2013, 03:17 PM
wrangler9754
1977 CJ5
i used the seal from morris 4x4 center and it fit fine
wrangler9754 is offline
post #3 of 15 Old 10-20-2013, 03:44 PM
sbcranger
I used the crown seals that came with my aftermarket frame and glass. Both fit well
sbcranger is offline
post #4 of 15 Old 10-20-2013, 05:25 PM Thread Starter
wsmutch
Is Omix ada better than crown?
wsmutch is offline
post #5 of 15 Old 10-20-2013, 05:42 PM
sbcranger
I would imagine that type of stuff probably comes from the same factories.
post #6 of 15 Old 10-21-2013, 06:07 AM
gmakra
Actually I did some research and there are several companies out there that do weather stripping for Jeeps. I try to stay away from Omix Ada and Crown I bought mine from here.
http://www.1aauto.com/1A/Weatherstrip/Jeep/CJ7
gmakra is offline
post #7 of 15 Old 10-21-2013, 06:33 AM
keith460
Jeep. There's Only One
keith460's Avatar
I bought my Cowl Seal from J&G Classic Jeeps, its aftermarket of course but it is the best one out there. Talk to George Yezman @ (734) 624-4775 from J&G Classic Jeeps who will give you a better price. He has been restoring Jeeps for years and knows what the best seals are that are out there.
I was able to get my windshield glass seal from the local auto glass company who installed my windshield glass. The seal and labor to install was $80.00.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 15 Old 10-21-2013, 08:43 AM
1984Laredo
X2 on the cowl seal from J&G. I went through several of the cheap cowl seals from Crown and Omix-Ada before getting this one. There really is no comparison in terms of quality. I still had fitment problems with the front flap of the seal not wanting straighten out and lie flat against the front of the windshield frame (even after HOURS AND HOURS of repositioning, trying tape that didnt hold, and finally had to resort to weatherstripping sealant). After all that, it still fit better than the cheap ones.
I also bought the Crown windshield and hardtop lift gate glass seal. Both pieces of junk and wasted money. Both were too long! The windshield seal was just too much material to cause it to kind of roll up in places, causing a leak. The lift gate glass seal was 1.5" too long, and I had to cut a 1.5" section out of the seal to even be able to put the glass in! I have read where seceral others have encountered this issue, as well. Don't know how, but so far that joint I made where the 2 ends of the seal meet hasn't leaked yet, even without any weatherstripping sealant on it.
1984 CJ7 Laredo
4.0 I-6 / T5 / D300 / D30 / D44
Black Diamond 3" lift, 33" tires, 4.11 gears
1984Laredo is offline
post #9 of 15 Old 10-21-2013, 10:26 AM
80cj
80cj's Avatar
1980 CJ5
That's what I would do.
A friend tried to install the glass himself and ended up cracking it. It's probably worth it to have a professional do it.
80cj is offline
post #10 of 15 Old 10-21-2013, 04:36 PM
james04si
james04si's Avatar
1977 CJ5
I have replaced my windshield seal a half dozen times using both crown and omix-ada with no issues and never worried about cracking it. Just take it slow and easy, rope and a bottle of soapy water go a long way. Ohh yeah and I didn't replace them because of leaks just fixing,painting,and repainting my windshield. Same with cowl seals and remember the windshield hinges can be loosened to adjust for any gaps from different cowl seal thicknesses.
One last thing to consider is the cowl fresh air vent for the heater. Those leaking behind the dash can be mistaken as windshield leaks.
james04si is offline
post #11 of 15 Old 10-21-2013, 06:08 PM
80cj
80cj's Avatar
1980 CJ5
Yeah, I found that out. Scratched my head for a while trying to locate the leak.
80cj is offline
post #12 of 15 Old 10-21-2013, 07:35 PM
JrTjK
1978 FSJ Wagoneer
I just did the Crown seals on my 85 (windshield, cowl, & tailgate) and they all fit perfectly.
JrTjK is offline
post #13 of 15 Old 11-19-2013, 11:27 AM
1Aauto
Vendor
1Aauto's Avatar
Thank you
SHOP HERE FOR AWESOME
1Aauto is offline
post #14 of 15 Old 11-19-2013, 11:34 AM
bdatkins
1978 CJ5
I did mine with Crown and it fit fine, but man, what a pain. If I had to do it over again, I would probably have it installed.
bdatkins is offline
post #15 of 15 Old 11-19-2013, 02:51 PM
commadore64
commadore64's Avatar
1980 CJ5
If you have a new WS frame and trouble getting the cowl seal to fit right, check out my build thread posts #201 & #210... the frame may have to be modified.
1980 CJ-5
My build thread:
Liberalism is the reason why everything else is a problem.
commadore64 is offline
