I hate electical - JeepForum.com
post #1 of 6 Old 01-08-2010, 03:23 PM Thread Starter
CopenhageCowboy
I hate electical
So i mounted some new fog lights on my jeep but when i connected the power to the fusebox the fusable link fuse blew, as well as the power to my cd player, cigarette lighter plug thing, and my heater. its cold and i cant drive hearing my engine and tires all the time. i checked the wiring on the other side of the fusebox and didnt see any burnt wires, and the fuses are fine, but there are 3 spots on my fusebox that arent getting power anymore, they happen to all be next to eachother. turned out my hot wire from the lights got pinched in the dash panel and shorted when it touched the body. but i want my heat and radio back! helpp please
Cj's are like spoiled children, they use up every penny you earn and never seem appreciative. But no matter what happens you still love them. :]
CopenhageCowboy is offline
post #2 of 6 Old 01-08-2010, 03:30 PM
CSP
So undo whatever caused the short and replace the fusable link.
CSP is offline
post #3 of 6 Old 01-08-2010, 03:34 PM Thread Starter
CopenhageCowboy
i replaced the fusable link but it was running from the light switch to the fuse box. and we ran the lights directly to the battery so that we wouldnt mess anything else up. but the heater and stuff still doesnt work
post #4 of 6 Old 01-08-2010, 10:03 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
First, you should be running a relay to all your external high draw appliances. This allows you to run fused leads directly from the battery or solenoid. It also keeps you from overloading the existing fusebox.
That being said, you will need to test each fuse and holder with a test light. If you find everything dead, then drop the box and inspect the back of it for any damage. If you find none, you will need to identify the dead lead and trace it back.
jeepdaddy2000 is offline
post #5 of 6 Old 01-08-2010, 10:27 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Turn Signal Also Dead?
Here is a schematic of the fuse box and ignition switch.
There are two fuseable link and if the one for the fuse box blew then nothing will work.
But there could be a problem with the fuse box and or ignition switch so you will have to get out your test light and start finding out were the power stops.
John Strenk is offline
post #6 of 6 Old 01-09-2010, 01:07 AM
OldSailor
1977 CJ7
For anyone modifying or contemplating modifying anything in the electrical system of a vehicle, I'd strongly suggest going to your local community college and taking a basic electricity course. Well worth the expense and time.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
Mechanical gauges DEFINETELY better than the stock electical gauges jeepguy85 Jeep CJ Forum 33 01-14-2010 08:20 PM
small electical problem JeromyCJ7 Jeep CJ Forum 1 02-18-2007 06:36 AM
Under Hood Horn Electical Question?? Mud Machine Jeep CJ Forum 7 08-14-2006 03:04 PM
staring/electical problem jetskibob1 Jeep CJ Forum 2 11-01-2005 03:02 AM
quick electical Qs onesojourner Jeep CJ Forum 3 02-18-2003 02:19 PM
