I grabbed one up. Finally! - Page 4 - JeepForum.com
post #46 of 47 Old 09-07-2009, 12:38 AM Thread Starter
apfroggy0408
1982 CJ7
Recently just fixed a few things here and there to get her running nicely.
Started off by starting to stall when slowing down to stop and it was because of a vacuum leak so we compensated by upping the idle. We got all the vacuum leaks taken care of (so I believe) but then the Jeep started dieseling.
On my way to my uncles to get the idle down to a good rpm the bikini top tore off and then shortly after that the top radiator hose blew and luckily the engine didn't overheat. There was a tire shop near by that let me use their water hose to fill up the radiator and reservoir and we cut the hose and placed it back in. Got the new hose lowered the idle and she drives beautifully.
Guess it's true "You know you drive a CJ when you break something new everyday".
The right headlight has broken mounting points so we cannot adjust it to straighten out so we have a temporary fix. (If you have any extras or parting out please shoot me a PM)
Since the fix she drives a lot stronger now and doesn't drink up to much fuel!
Life is great with my jeep.
apfroggy0408 is offline
post #47 of 47 Old 09-09-2009, 03:07 PM Thread Starter
apfroggy0408
1982 CJ7
New problem and have been searching like crazy for an answer.
Jeep is now giving problems when trying to start. It cranks but will not turn over until it seems to be a random point after I've started trying. Been messing around with the throttle and that usually gets it to eventually turn over.
I've read of similar problems and of people just finding the sweet spot for the jeep with the amount of presses to the floor on the throttle and such. But the jeep would start immediately before.
Now my question is could this be due to us possibly making the idle to low? Or could it be some kind of new cause in my Jeep adventure?
Edit: Got a BBD just to let you know with electric choke
Finally Got It. cracked91 Jeep CJ Forum 0 05-24-2009 05:04 PM
finally got me a CJ!!! chadwick66 Jeep CJ Forum 50 12-22-2008 07:31 PM
Finally got a CJ Blue70 Jeep CJ Forum 5 03-04-2008 10:09 AM
79 CJ5 Finally Done! mustangdave357 Jeep CJ Forum 1 07-10-2007 09:58 PM
Finally GKB Jeep CJ Forum 0 03-28-2005 08:50 AM
