I got no spark - JeepForum.com
post #1 of 4 Old 09-13-2011, 08:42 PM Thread Starter
eddy2324
I got no spark
When I pulled this CJ out of the weeds and turned the key the starter clicked.
Since then I have been taking body stuff off, I don't think I unplugged any wires under the hood.
I did however try to remove the dash and in doing so the switch, that is under the dash by your left knee when sitting in the driver seat, wires are not attached to anything.
Now when I turn the key I get nothing. No spark even at the points inside the distributor cap. I bought a brand new battery today and was hoping to get this thing running but that can't happen without spark.
Does my problem have anything to do with electrical behind the dash? Any suggestions would be greatly appreciated.
eddy2324 is offline
post #2 of 4 Old 09-13-2011, 09:20 PM
CrescentMoon
1978 CJ5
I'm still learning, myself... But, if I were you, I would make sure that all of the wiring is connected where they should be. If you're not sure post pics of any areas that are questionable. Your post doesn't really give much info or history. How's your starter solenoid? It's cheap to replace if needed. What about your ignition module? (that's cheap too) Battery cables? Are they clean? Did you put a new battery in it yet? Check out my thread "I need help! Please?!" (I think that's right) I've been learning as I go, posting lots of pics, & asking a lot of questions! Some of it may help you.
Hope this helps...
CrescentMoon is offline
post #3 of 4 Old 09-13-2011, 09:53 PM
BagusJeep
1981 CJ7
That key thing, does it look like the ignition switch? Sounds like it might be the light switch.
Are you getting anything, even lights or horn?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 4 Old 09-14-2011, 07:49 AM Thread Starter
eddy2324
a buddy of mine and i went out yesterday with a brand new battery and were getting the motor to turn over by crossing the solenoid on the starter. so everything is good as far as that goes. i just don't have spark going to the plugs.
bagusjeep: the switch i am talking about is a like a toggle switch. it is mounted on the under side of the dash. next time i get out there i will take some pictures. ran out of time yesterday.
eddy2324 is offline
cj5 , engine , no spark
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 04:36 PM
HEI, Weak spark at coil, no spark at plugs Deadman 94 xj Jeep CJ Forum 13 07-30-2011 08:49 AM
HEI No Spark help adamsclarke Jeep CJ Forum 2 11-16-2009 09:29 PM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 09:02 PM
No Spark MFairbourn Jeep CJ Forum 2 12-21-2004 09:31 PM
