I D this scout axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I D this scout axle
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-30-2007, 09:22 PM   #1
Mr.Crowley
1980 CJ7
I D this scout axle
I found a set of scout axles for sale localy..The seller is unsure of the details like year and what not..Can anything be gathered by this pic?
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Unread 12-01-2007, 09:34 AM   #2
jeepdaddy2000
1971 CJ5
http://www.binderbulletin.org/forums/?&
Might try these guys. Good crew over there.
jeepdaddy2000 is offline   Reply With Quote
Unread 12-01-2007, 09:36 AM   #3
flexncj7
Dana 44- Disc Brakes means its 1974-1980
74-79 are all the same, the 1980 has a slightly better castor angle.
1985? Jeep CJ-7: 360, 999, D300, LOMAX 4:1, Dana 44s, 4.10's, Aussies front & Detroit rear. S0A, York OBA, YJ tub, 36" IROKs-
1989 YJ Sahara: 258, puko tranny, np231. 2-3" spring and 2" body lift. 33" TSLs- latest project.
flexncj7 is offline   Reply With Quote
Unread 12-01-2007, 09:49 AM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
IIRC all but the 80 have 0 degrees steering caster. They also have those hideously long steering arms and external hubs. Swapping GM/Waggie knuckles (preferebly flat tops) can solve the steering arm issue and give you internal hubs.
Not sure of the axle width.. 58-59 inches or so?
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 12-01-2007, 01:01 PM   #5
Mr.Crowley
1980 CJ7
thank you all..just wanted to make sure there wasnt anything funky about this axle..like the odd ball .01%that IH may have made..Murphy's my co-pilot..is 160 a good price?there not too common for around my parts so im gonna buy them either way..
thanks scott
[QUOTE=Me]
:hahaha: yj
Unread 12-03-2007, 07:40 AM   #6
jpfaris
1979 CJ7
Not an outrageous price, but I bought a complete Scout with the engine siezed for $200. Grabbbed the axles and traded the rest in at the junkyard.
79 CJ7, 304, TF727, D300, FULL WIDTH D44's, 4.56:1, SPOOL LOCKERS, SOA, OUTBOARDED, SHACKLES REVERSED, HOMEMADE D-SHAFTS, 38.5" BOGGERS
jpfaris is offline   Reply With Quote
