I can't get my tach to work...! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I can't get my tach to work...!
Poison Spyder Full Cage Kits with Lazer-Fit featuresThe Ruffstuff 9" Disc Brake brackets!The Cure for your Tie Rod Roll!
Unread 04-06-2005, 09:41 AM   #1
Timmy.o.tool
This is on my YJ but it is an 89 and has the same setup that most of you CJ kids are running here is a link to the thread in the YJ forum. Any help would be great. I would like to fix this before I head to florida next week but if I don't oh well.
http://www.jeepforum.com/forum/showp...85&postcount=1
thanks,
tim
1989 YJ Underland
2003 WJ Overland
Timmy.o.tool is offline   Reply With Quote Quick reply to this message
Unread 04-06-2005, 10:34 AM   #2
Geer_hed
You tried the monsterslayer writeup? Not sure how similar that is to your setup.... And I believe the tach does run to coil negative, but it sounds like you've got something else going on.
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote Quick reply to this message
Unread 04-06-2005, 02:53 PM   #3
84laredo
I just recenlty installed a tach on a cj. If everything else is hooked up (i.e. pwr, lights) as far as I can tell you just need the wire from the (-) coil terminal to the tach.
84laredo is offline   Reply With Quote Quick reply to this message
Unread 04-06-2005, 03:11 PM   #4
84laredo
Unread 04-06-2005, 09:15 PM   #5
Timmy.o.tool
sweet then all I have to do is figure out which wire coming off the tach to use... hmm I'll get that done tomorrow.
Thanks hopefully I will have figured out before the weekend.
tim
1989 YJ Underland
2003 WJ Overland
