I Can't find my temp sending unit HELP!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > I Can't find my temp sending unit HELP!!!!
Unread 02-19-2002, 09:41 AM   #1
OfFtHeWaLl
Red face I Can't find my temp sending unit HELP!!!!
Boy this is tough to admit.. I have looked in my cj book and cant find it. I need to replace my inline 4cy engine temp sender so i can get a readout on my dash, Butt I cant find it! any help would be great! I had the part (bought at a auto store butt they were no help in locating the location. So if ya had the same prob please let me know. I have looked for pics butt can't find any.. Thx
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
it's my problem child
butt i love it
OfFtHeWaLl is offline   Reply With Quote Quick reply to this message
Unread 02-19-2002, 09:43 AM   #2
OfFtHeWaLl
Post
Oh ya and my fuel guage does work and the connections are good so I think it has to be a bad sender unit
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
butt i love it
Unread 02-20-2002, 02:25 PM   #3
Guy Hollister
Cool
On the I6 its at the back - by the firewall... on the LHS - its a rod thats about an inch high and has a wire coming off it - or in your case MIGHT NOT !
They're cheap to replace but a prick to remove.
Guy
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline   Reply With Quote Quick reply to this message
Unread 02-20-2002, 02:26 PM   #4
Guy Hollister
Cool
oops - thats on the top of the rocker cover.
g
1984 RHD CJ7
1979 LHD CJ5
Unread 02-20-2002, 02:29 PM   #5
Guy Hollister
Cool
Whats your problem again ???
I had a prob that sounds like your are on the same track with solving as i was ... its the wrong track.
It turned out to be the two wires... one on each the temp unit and the fuel gauge .. just pull em off and start the jip... then reseat them both ... and wiggle about till temp gauge drops to normal... it will work - try it. Bad contact and needs resetting.
g
1984 RHD CJ7
1979 LHD CJ5
Unread 02-20-2002, 02:43 PM   #6
OfFtHeWaLl
Post
Well i tried taking off both the plugs and then turned it on let it run for a min and shut it off and putt back on both butt it dint work.. my temp gage is not stuck on hot its just not working just like my fuel...itys odd because both are pritty new looking....butt thanks for the info do i need to keep them off for a bit or does it reset right away?
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
butt i love it
Unread 02-22-2002, 02:30 PM   #7
JEEPIN DAKOTA
Post
SOUNDS LIKE IT COULD BE A FUSE OR THE GAGES JUST GAVE OUT. WITH THE FUEL CHECK YOUR WIRES OUT REALLY GOOD. I HAD TO TAKE MY TANK OUT OUNCE AND ENDED UP PINCHING ONE OF THE WIRES. AS FOR THE TEMP. SENDING UNIT YOU MIGHT FIND IT ON THE HEAD, DRIVERS SIDE, CLOSE TO THE FIRE WALL.
JEEPIN DAKOTA is offline   Reply With Quote Quick reply to this message
Unread 02-23-2002, 10:54 AM   #8
Guy Hollister
Cool
will reset right away ... when you replace them - move them round till the needles move... it may be you have a bad contact inside that rubber pluy thingy... as i did... i rolled up a bit of sand paper and poked it in then spun it round and it was sorted...
g
1984 RHD CJ7
1979 LHD CJ5
Unread 02-25-2002, 09:25 AM   #9
OfFtHeWaLl
Post
Well i found my sending unit (after scrubbing the engine clean!!! it was under a bunch of goop!!! The guy woh had this befor me was a slob!!!! Anyway it was towrd the back on the drivers side right by the cover bolts. I replaced it and my gages still wont work.. So im still trying to fix my gages...
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
butt i love it
