I broke something - JeepForum.com
post #1 of 7 Old 03-18-2013, 03:30 PM Thread Starter
Scott1984CJ7
I broke something
I'm rebuilding my 1984 CJ7 and pulled the dash to replace everything...all gauges, lights, switches and controls.
Put it back together and I'm having a couple problems:
1. I keep blowing my BU/seatbelt 25 amp fuse
2. It starts, and sounds like the trans is engaging, but it won't move (in any gear)
3. Having a flasher problem (replaced the flasher module but no help)
Hoping someone can help with some of this.
Thx-Scott
Scott1984CJ7 is offline
post #2 of 7 Old 03-18-2013, 03:36 PM
19jeep85
Sounds like you moved the transfer case into neutral. Try moving it back into gear.
The heart of the wise inclines to the right, but the heart of the fool to the left .
19jeep85 is offline
post #3 of 7 Old 03-18-2013, 03:56 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
my '84 doesn't have a BU/Seatbelt fuse, much less a lead for it? and its a Laredo? did you pinch a wire putting it all back together? or ground one that shouldn't be grounded?
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #4 of 7 Old 03-18-2013, 05:19 PM
brownbagg
1930 MK Compass
i say 1 and three are related, you shorted a wire or ground wire hook in wrong place
brownbagg is offline
post #5 of 7 Old 03-18-2013, 06:29 PM
jeep1000
These are all very good possibilities. Nothing else to suggest.
Jonathan
'86 CJ7, I6 258 four speed manual. See ya on the trails!
jeep1000 is offline
post #6 of 7 Old 03-20-2013, 08:52 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This happened to me and I was totally panicked. It's easy to do but easy to fix.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #7 of 7 Old 03-21-2013, 04:57 AM
BagusJeep
1981 CJ7
IF you put it all back together properly these are the circuits in a 1984 standard fuse box. The large diagram is from a Wagonner which had the same fuse box but the schematic is for a 1984-86 CJ. You will be looking for Red wires that are shorted or not connected to what it should have been. There are a number of Red wires as they are live with the Ignition in ON and START.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
1984 , cj7 , electrical problem
