-   -   I broke something (http://www.jeepforum.com/forum/f8/i-broke-something-1495390/)
Scott1984CJ7 03-18-2013 02:30 PM
I broke something
:confused:
I'm rebuilding my 1984 CJ7 and pulled the dash to replace everything...all gauges, lights, switches and controls.
Put it back together and I'm having a couple problems:
1. I keep blowing my BU/seatbelt 25 amp fuse
2. It starts, and sounds like the trans is engaging, but it won't move (in any gear)
3. Having a flasher problem (replaced the flasher module but no help)
Hoping someone can help with some of this.
Thx-Scott
19jeep85 03-18-2013 02:36 PM
Sounds like you moved the transfer case into neutral. Try moving it back into gear.
frhrwa 03-18-2013 02:56 PM
my '84 doesn't have a BU/Seatbelt fuse, much less a lead for it? and its a Laredo? did you pinch a wire putting it all back together? or ground one that shouldn't be grounded?
brownbagg 03-18-2013 04:19 PM
i say 1 and three are related, you shorted a wire or ground wire hook in wrong place
jeep1000 03-18-2013 05:29 PM
These are all very good possibilities. Nothing else to suggest.
Ken4444 03-20-2013 07:52 PM
929 Attachment(s)
This happened to me and I was totally panicked. It's easy to do but easy to fix.
BagusJeep 03-21-2013 03:57 AM
3 Attachment(s)
IF you put it all back together properly these are the circuits in a 1984 standard fuse box. The large diagram is from a Wagonner which had the same fuse box but the schematic is for a 1984-86 CJ. You will be looking for Red wires that are shorted or not connected to what it should have been. There are a number of Red wires as they are live with the Ignition in ON and START.
The time now is 07:58 PM.
