I broke my Yoke! - JeepForum.com
post #1 of 4 Old 06-15-2003, 05:45 PM Thread Starter
MAC
Exclamation I broke my Yoke!
Well guys I broke my yoke. Actually I broke the saddles holding the U-Joint in place. What can I do when I replace this to ensure that it wont happen again. It happened just on a regular drive to the store! They probably vibrated loose (I have a 350). but how could I stop this from happening again
MAC is offline
post #2 of 4 Old 06-16-2003, 06:18 AM
mxg342
mxg342's Avatar
I would replace the yoke with one that allows for the u bolt mounts instead of the straps. Depending on your setup, you maight have to buy a new yoke or just drill the holes out. I'll see if I can get you a website on this conversion.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 4 Old 06-16-2003, 06:19 AM
mxg342
mxg342's Avatar
Check this site out.
http://www.jeeptech.com/axle/aub.html
mxg342 is offline
post #4 of 4 Old 06-16-2003, 10:26 PM
eight
eight's Avatar
Get out your 5/16" drill bit and drill out the threads. Use a u-bolt from the HELP section at your auto parts store that says FORD on it. There are only 3 different types of u-bolts, one for stock yoke with 1310 or 1330, one for 1350, and this ford one that I'm not sure what it's stock application is but the round part fits the 1310 u-joint (stock) and the bolt parts are wider than the normal 1310 style u-bolt and the right width for this mod.
eight is offline
cj7 yoke stoneywaves Jeep CJ Forum 10 07-19-2009 05:34 AM
NO YOKE! I Can't Get It Off! skidplate77 Jeep CJ Forum 7 12-14-2008 06:47 PM
Whats the difference b/w a Strap Style Yoke and a CV Yoke? BigTal Jeep CJ Forum 9 07-18-2007 10:32 AM
Yoke? cj5one Jeep CJ Forum 5 09-01-2006 08:49 AM
YOke thenubsterman Jeep CJ Forum 3 08-30-2005 02:41 AM
