I-6 to V-8 FlyWheel Swap - JeepForum.com
post #1 of 6 Old 07-02-2010, 11:36 AM Thread Starter
BinghamtonCJ5
1978 CJ5
I am swaping out an Inline 6 cyl for an AMC 360 V8 and the flywheel from the 6 fits right on and bolts up to the 360. I am just checking if there is any reason why I can not use the flywheel for this application. Any help will be appreciated.
Happy 4th weekend everyone
BinghamtonCJ5 is offline
post #2 of 6 Old 07-02-2010, 11:47 AM
CSP
The I6 is internally balanced so the flywheel had neutral balance. The V8 is externally balanced (using the flywheel and harmonic balancer) and there is a displacement specific flywheel for every engine (304, 360, 401, etc). You must use the correct flywheel or have your maching shop balance the I6 flywheel to the 360 specs (if they can).
CSP is offline
post #3 of 6 Old 07-02-2010, 11:58 AM Thread Starter
BinghamtonCJ5
1978 CJ5
thanks for the answer, maybe you could help me with the next part, there are two different clutch sizes does it matter what wich one I use with it, I have the choice of either a 10 1/2" or 11".
Thanks
post #4 of 6 Old 07-02-2010, 12:08 PM Thread Starter
BinghamtonCJ5
1978 CJ5
and with a little bit of research I answered my own question, I do see that not all FlyWheels are drilled for both clutch's
post #5 of 6 Old 07-05-2010, 12:13 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
x2
Binghamton, people will tell you not to bother or that they did it and it was "close enough". Don't go there. Do it the right way.
Also, beware Autozone's inexpensive flywheel line. They show the same part number for both 304s and 360s on one of their brands of flywheels. Nobody has documented which application that product is really weighted for, so steer clear of it.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #6 of 6 Old 07-05-2010, 01:31 PM
flashawk
flashawk's Avatar
1979 CJ5
My 360 is internally balanced so I used the I6 258 flywheel rather than having one done at a machine shop for me. Hays make some pretty good billet flywheels for all AMC motors balanced to either neutral (internal) or Detroit (external) specifications.
1979 CJ5 360 V8 w/Holley 470 Truck Avenger, HEI Ignition, Livewires w/E3 Sparkplugs, Hedman Hedders, Flowmasters, DANA 30 w/Auzzie Locker, AMC 20 limited slip "N" 3:54's, Tuff Country 2.5" lift, Rancho RS5118, Rubicon Express Quick Disconnects, Currie 1/2" lift Heavy Duty Greasable Shackles, DANA 20, T150, Mile Marker PE8000 w/MiFi Controll Box, Bestop Super Top, Warn 6 bolt Premiums, 31x10.50x15
flashawk is offline
304 to 360 do I really need a new flywheel JohnnyRotten Jeep CJ Forum 19 03-29-2010 02:26 PM
sb chev swap, flywheel ? rodjr Jeep CJ Forum 2 03-26-2009 10:54 PM
flywheel diver49 Jeep CJ Forum 2 02-27-2008 01:43 PM
Flywheel with 360 swap... scrible Jeep CJ Forum 1 11-06-2006 03:25 PM
304 flywheel mojotomred Jeep CJ Forum 0 05-22-2004 06:13 PM
