I NO LONGER RECOMMEND AUTOLITE PLUG WIRES!
I HAVE HAD REAL TROUBLE WITH THEM IN THE PAST TWO YEARS AND I NO LONGER RECOMMEND THEM!
IF YOU WANT 'OFF THE SHELF' WIRES,
Then Use 'Motorcraft' brand wires instead,
They seem to still be fairly well made...
PARTS LIST, Advance Auto,
Advance Auto, DISTRIBUTOR CAP p/n C193 from Borg Warner.
Advance Auto, ROTOR p/n D219Z from Borg Warner.
Advance Auto, CAP ADAPTER p/n C193AP from Borg Warner.
Advance Auto, PLUG WIRES p/n WR4050 from Motorcraft.
(Comes with BOTH coil wires, E-core coils are NOT recommended with stock ignition modules)
PARTS LIST, Auto Zone
Auto Zone, Cap Adapter, $4.99, p/n F960
Auto Zone, Distributor Cap, $20.99, p/n F2104G
Auto Zone, Rotor, $3.99, p/n F953
Auto Zone, Plug Wires, Motorcraft p/n WR4050
(Comes with both types of coil wires, E-core coils are NOT recommended with stock ignition modules.)
YOU DO NOT HAVE TO CHANGE COILS!
The Factory canister coils is perfectly fine for 99% of the I-6 engines this is going to be used on,
And if you switch coils,
I suggest you use an MSD Blaster 2F, p/n 8205
Fits right in your stock bracket, connects directly to your factory harness and works better than the orignal from the factory.
Keep in mind that most of you have a 25+ year old coil in your vehicles!
This might be a good time to retire it for something a little better and a BUNCH NEWER!
Decide on CANISTER COIL or E-core coil.
MY Suggestion is to use your FACTORY STYLE COIL
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-8205&N=700+115&autoview=sku
YOU DO NOT HAVE TO CHANGE COILS OR BUY A NEW COIL.
Some people upgrade to an MSD factory style coil (Blaster 2F)
OR,
They use a Ford E-core coil, or an MSD E-core coil.
(Ford, junk yard for about $5. Don't forget to get the coil bracket and coil electrical connector plug if you do!
MSD coil p/n 8227
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-8227&N=700+115&autoview=sku
If you buy a new coil, you will need to fabricate a bracket,
AND,
You will need to purchase a coil connector,
NAPA p/n ICC1, $15.
PLUG WIRES,
Factory Ignition Coil, Autolite p/n 96171
E-core coil, Autolite p/n 96624
NEW PREMIUM PLUGS FOR YOUR YEAR/ENGINE.
All years are different, so I can't give specific part numbers for all variations, altitudes, ect.
Suggestion is to use Autolite or Denso, and gap to 0.045" regardless of the engine you have or what the book says.
Tube of 'Never-Seize'.
Tube of 'Tune Up Grease' (Dielectric Grease)
Tube of Butyl or Silicone caulking, or Weather Strip Adhesive (optional).
TOOLS.
One medium sized flat blade screwdriver,
One medium sized (#2 Phillips) cross screw driver,
One plug socket and drive tool,
Plug gap checker,
Needle nose pliers.
This is about what your 'PIG' should look like...
TAKE NOTE of where the #1 (front) cylinder plug wire is located on the cap, and then mark that location on the distributor base...
(so you can find it again with the new cap!)
This is showing me marking the distributor cap #1 terminal, but you need to MARK THE DISTRIBUTOR HOUSING, not the cap like I'm showing...
(My mark on the distributor HOUSING wouldn't show up in pictures, so we marked the cap to illustrate that you need to know where #1 plug wires terminal is located RIGHT NOW!)
*IF*, and this is a BIG *IF*...
Your distributor is installed correctly, your #1 terminal mark will be on the housing where the rotor is now pointing. (your rotor will likely be pointing someplace else, but I have this one turned to point at where the #1 plug wire terminal MARK should be for illustration purposes.)
Start with the DISTRIBUTOR CAP ADAPTER...
That would be the GRAY THING on the RIGHT in this picture...
I often put some 'butyl' or 'silicone' sealer on the bottom edge of the adapter before it screw it down to the distributor.
This helps keep A BUNCH of water out of the distributor.
Your ignition distributor won't by any means be 'Water Proof', but it WILL help keep a large source of water in the distributor OUT!
Since the adapter doesn't have to be removed very often, you can 'Glue' it down with 'Weather Strip Adhesive' if you want to keep a BUNCH of water out!
I DO NOT use the blue 'RTV' sealer or 'Form-A-Gasket', since they off gas a LOT of acids while curing... ACIDS & Electronics don't get alone well!
Here is what the adapter and new rotor look like installed...
Put a 'Dab' of 'Tune Up Grease' on the rotor NOSE. Just a little 'dab'.
'Tune Up Grease', or Dielectric grease IS NOT never sizes or caulking/sealer!
Once adapter and rotor are installed, slap the cap on the adapter...
DO NOT forget to put some 'tune up' grease in the groove on the UNDERSIDE of the distributor cap!
(In the groove only.)
This will seal the cap to the adapter and keep one source of water out of the distributor, but still allow you to get the cap off at any time.
Now, with distributor 'Tune Up' parts in place,
You are ready to do the plugs...
Make sure they are properly gapped,
DO NOT Pry on the center electrode to gap them!
DO NOT bang on the 'Ground' electrode to close up the gap!
Modern 'Resistor' plugs are VERY SENSITIVE!
Use a pair of NEEDLE NOSE pliers to bend the 'Ground' electrode instead of PRYING on the center electrode! That's the WORST thing you can do to a spark plug (Prying on the center electrode or 'Tapping' the gap closed!)
They have a 'Carbon Pile' resistor inside the insulator, and if you break that very fragile carbon, 1/6 of your horsepower and torque goes right out the window!
IF YOU DROP A PLUG ON THE GROUND, REPLACE IT!
I can't stress this enough!
This is probably the #1 reason for 'Loss Of Power' or 'Poor Economy' complaints after a 'Tune Up'!
People just don't realize how fragile the plugs are!
You don't need a ton of 'Never Seize' on the threads, but you DO need to use it (Copper if you can find it, but zinc is OK if you can't turn it up easily or Copper is too expensive for your project)
PLUG WIRE TIME,
Use AT LEAST Autolite brand plug wires!
The cheap 'Store Brands' or 'Private Label' brands are CRAP!
MSD wires are without question the best wires on the market, but they are $65+ !!!
For a low revving I-6 engine, the Autolite wires should do you fine.
Use a 'Q-Tip' and put a little dab of dielectric grease (Tune Up grease) in each end of each plug boot.
(If you use factory coil, DO NOT grease the coil end of the coil wire, everything with a 'Spark Plug' terminal gets it!)
This will help keep the water from your connections, and that will keep the ignition from grounding out, and it will keep the terminals from corroding.
The grease also keeps the boots from drying out and cracking.
NOW, If you take a CLOSE LOOK, you will see I mark the FIRING ORDER, starting with the #1 plug wire position, on the cap.
this makes things A LOT MORE SIMPLE! (Old racing trick!)
AMC I-6 FIRING ORDER... 1-5-3-6-2-4 CLOCK WISE!
Cylinders are numbered 1-2-3-4-5-6 Front To Back.
SOMETIMES, when I'm doing this upgrade,
I notice the factory coil connector has seen MUCH better days!
The terminals in the connector are shot, the wires are about broke off the terminals from vibration and corrosion, and it's generally in BAD SHAPE!
These are cheap (around $7) and available from Auto Zone or NAPA.
This one is from Auto Zone...
EASY TO INSTALL, clip the wires to the old one, and use crimp connectors with heat shrink tubing to seal up the splice, and you are DONE!
BAD COIL CONNECTOR is a VERY COMMON PROBLEM, and the cause of that mystery 'No Start' or mystery 'Shut Off' problem so many people experience,
BUT,
Since it's an INTERMITTENT problem, it's VERY hard to trace!
Unless you changed the coil to an 'E-core', you are DONE!
That's all there is to it! A simple ignition 'Tune Up' but using PREMIUM PARTS!
*IF*, you did change the coil to an 'E-core', you will need a new coil connector.
Clip the wires going to the factory coil connector,
Match up the wires to the E-core coil connector, RED TO RED, Green To Green.
Don't forget mount the coil!
(Yes, I've got every thing done, and test drove, just to get back and find the coil hanging by the wires!)
WHY YOU ARE DOING THIS UPGRADE, AND WHAT IT'S DOING FOR YOU...
The small cap and short rotor from the factory allow the SPARK ENERGY to bounce around inside the distributor cap like crazy!
If you ever cut a hole in the distributor cap, and run the engine at night so you can see it, those small caps look like a fireworks display!
The spark energy jumping from the coil terminal to the distributor housing is called a 'Ground Fire'.
This means one of your cylinders, 1/3 of the power for that engine revolution, went right out the exhaust pipe without ever contributing!
Using the TALLER ROTOR lifts the spark energy up, away from the housing and distributor shaft, virtually ELIMINATING the ground fire problem.
In fact, you can actually feed MORE spark energy through the taller rotor without fear of ground fires!
It's FREE ENERGY going to your spark plugs instead of going to ground fires where it does you NO good!
The spark energy jumping to the WRONG terminal at the very least is 1/3 of the power for the RPM going out the exhaust....
IF YOU ARE LUCKY!
You see, if that spark jumped to a cylinder that was on the EXHAUST STROKE, the spark was wasted, and didn't fire the cylinder it was supposed to...
BUT...
IF that spark fires the cylinder AHEAD of the one it's supposed to,
It's firing the cylinder 120° TOO SOON in the firing order!
Think about that for a minute...
3° or 4° too much timing can cause detonation in your engine,
But people ROUTINELY allow 120° TOO MUCH TIMING ADVANCE without doing ANYTHING ABOUT IT!
That's like hitting the piston with a SLEDGE HAMMER and can break pistons, break valves, ruin rods and bearings, and a HOST of other things you don't even want to know about!
The WIDER cap spreads the terminals farther apart, making the CORRECT plug wire terminal the more attractive for the spark energy to jump to!
OR,
MSD coil p/n 8227
AND,
NAPA p/n ICC1, $15.
PLUG WIRES,
TOOLS.
Plug gap checker,
Needle nose pliers.
PLUG WIRE TIME,
BUT,
IF YOU ARE LUCKY!
BUT...
