I-6 'TeamRush Upgrade' (definitive) - Page 38 - JeepForum.com
 3Likes
post #556 of 765 Old 09-01-2013, 12:08 AM
tripster_sta
1979 CJ5
Installed everything today. Went the advance auto parts route with motorcraft wires and autolite coppers. My 79 is running better than before.
Looking to upgrade the coil and ignition control next using MSD.
Awesome thread JeepHammer. Please keep it up.
tripster_sta is offline
post #557 of 765 Old 09-29-2013, 07:18 PM
ReDinTX
I know this has been asked a lot before, but i cant find the specific answer im looking for.....
As far as the ballast resistor goes, for using an MSD coil, as i understand it, all this resistor does is drop the voltage to the coil to less than 12vdc so the coil wont burn up? I started my jeep and i had ~3vdc across the two wire terminals (+&-) and ~8-9vdc across the coil + and battery -. I take this to mean that i do NOT need the additional ballast resistor, that all i need to do is drop in the MSD Blaster 3 and wire it up just the the stock one and i'm good to go.....correct?
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #558 of 765 Old 10-02-2013, 09:46 AM
David2012
spark plugs
When doing this upgrade you mention the spark plugs. Does this mean that I have to replace my plugs or is it just for tune ups sake? I just put my plugs in not to long ago but obviously if need be i will change them. What im wondering is if the new set up requires different plugs then found stock in the cjs. Thanks. and great write up with lots of amazing information
Electrical gremlins will be the death of me... 85 cj7
David2012 is offline
post #559 of 765 Old 10-02-2013, 10:03 AM
ReDinTX
Use ur same plugs, just open the gap up. .040"-.045"
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #560 of 765 Old 10-02-2013, 10:12 AM
David2012
Thanks! will do.
post #561 of 765 Old 10-02-2013, 11:14 AM
David2012
the wires however are 100% necessary? Or can the old (new) ones be used as well? I know it says it requires new ones but it also said that about the plugs so just making sure
post #562 of 765 Old 10-02-2013, 11:59 AM
jcalhoon84
1980 CJ5
You need new wires, the CJ ones won't attach to the new cap.
jcalhoon84 is offline
post #563 of 765 Old 10-02-2013, 12:19 PM
David2012
Thank you sir
post #564 of 765 Old 10-02-2013, 04:22 PM
ReDinTX
I got lifetime warranty Borg Warner 8mm wires at oreillys. They were like $26.
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #565 of 765 Old 10-03-2013, 06:44 AM
David2012
You get a noticeable performance gain out of it Red? Kind of excited to do this one after all the good things people have said about it.
post #566 of 765 Old 10-03-2013, 07:18 AM
ReDinTX
Will install on saturday
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #567 of 765 Old 10-08-2013, 07:01 PM
ReDinTX
Idle smoothed out a bit but i think im in need of a carb rebuild and fuel pump as well. The old coil confirmed my thoughts that i didnt need a resistor, and the plug wires were perfect length! Opened plugs up between .040 & .045. The whole thing took maybe 2 hrs and i was takin it slow. Longest part was gapping plugs!
Better throttle response and power curve seems smoother.
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #568 of 765 Old 10-08-2013, 09:13 PM
David2012
Thanks for the update Red. Going to do this sometime soon. Probably have my gf buy me the parts for my birthday haha!
do you have a part number for those wires? all the others im finding are like 40$
post #569 of 765 Old 10-09-2013, 12:17 AM
ReDinTX
Thanks for the update Red. Going to do this sometime soon. Probably have my gf buy me the parts for my birthday haha! do you have a part number for those wires? all the others im finding are like 40$
disregard the brake parts
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #570 of 765 Old 12-06-2013, 04:26 PM
AmmitOsiris
Let's see if ican get this shopping list so I can have mom give it to me from santa
Because I Saved 15% On My Car Insurance
AmmitOsiris is offline
Prestolite to teamrush upgrade- Amc 360 v8 2manytoys2 Jeep CJ Forum 13 10-26-2012 12:16 PM
TEAMRUSH Upgrade, Who SELLS PLUG WIRES?? Fjguercio Jeep CJ Forum 14 06-02-2010 08:16 PM
What is a TeamRush upgrade ? tevans59 Jeep CJ Forum 6 01-11-2010 06:02 PM
My TeamRush, Nutter & Weber 32/36 Upgrade for 1985 258 TJTony Jeep CJ Forum 3 01-11-2009 12:17 PM
Teamrush upgrade on 76 CJ5 76silvercj5 Jeep CJ Forum 9 08-26-2008 03:49 PM
