I-6 'TeamRush Upgrade' (definitive) - Page 37 - JeepForum.com
 4Likes
post #541 of 767 Old 06-04-2013, 05:45 PM
1sik78cj7
1978 CJ7
Originally Posted by jbdower View Post
This is how it looked brfore the upgrade, and after I did it, it would not start or even fire in this position.
I will try moving all the plug wires one space on the cap, clockwise. Then I'll set the distributor back to where it was (so it'll look like the picture above again)
I'll let you know how it goes. Thanks for the info
God, guts, guns....without them we have no FREEDOM!
1sik78cj7 is offline
post #542 of 767 Old 06-04-2013, 11:23 PM
fourbtgait
1930 MK Patriot
1. Did you pull the dizzy at all to do the upgrade? Or just add spacer, cap, rotor, wires?
2. Was the original wire on the #1 marked spot both before and after?
3. If you put the original cap, rotor, etc back, does it start right up in that same original dizzy position, but the new ones don't?
fourbtgait is offline
post #543 of 767 Old 06-05-2013, 01:06 PM
1sik78cj7
1978 CJ7
No I didn't pull the distributor. But i had it replaced at a shop about a year and a half ago because it wouldnt pass smog on the high end. The shop said the distributor was worn, they put in a new one and it smogged with no problem. I just had it smogged again for this year at a different place about a month ago and it passed with no problems.
Yes the #1 wire is in the same spot on the cap.
No, I haven't tried putting all the old stuff back on, this seems counter productive to me. I did the upgrade because it was hard to start when cold, ideled rough and would bog down really bad under a load, like going up an incline.
post #544 of 767 Old 06-05-2013, 02:07 PM
fourbtgait
1930 MK Patriot
Ok.
My original thought ran with a wore out dizzy and since yours is new the thought didnt apply. My TR gave me fits for a week to get it running.
post #545 of 767 Old 06-10-2013, 05:20 PM
1sik78cj7
1978 CJ7
I tried moving the wires and putting the distributor back in it's original position. It started but didn't run very well. So I put the wires back in the proper position on the cap and pulled the distributor and rotated it one tooth clockwise. I put it back in and adjusted it's position until the Jeep was running smoothly again. On a quick road test it seemed fine. I'm gonna take it out and drive up a few steep hills to see if it still bogs down as soon as I get a chance.
I feel better about not having the vaccum line right against the block. This is how it looks now:
post #546 of 767 Old 06-20-2013, 12:35 PM
1sik78cj7
1978 CJ7
I took the Jeep out for a longer road test and it worked great. Ran smooth, started easy even when the engine was hot. So far no more problems, I'm happy with the upgrade results. I would definately recommend doing this.
post #547 of 767 Old 06-20-2013, 06:59 PM
smokie123
1983 CJ7
Great thred!
smokie123 is offline
post #548 of 767 Old 06-20-2013, 08:24 PM
83vert
1982 CJ7
Originally Posted by smokie123
Okay, first I have to say I love this topic and all the great feedback. I do have one underlying question that keeps coming to mind as I read. WHY? What benefits does this upgrade have other than the ability to put Ford F150 parts on a Jeep? I'm excited about changing out my coil, that I understand. I'm not trying to be a smart *** by asking this I just want to better understand the benefits is all. Finally, thanks in advance for any responses you guys rock!!
Page#1 post#1
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #549 of 767 Old 07-30-2013, 04:10 PM
cvfd332
Hello gentleman , was planning on doing the team rush upgrade this weekend, but the jeep threw me a curve ball before I was able to start. I installed a radio and I'm sure hoping this is coincidence but after doing this jeep will not start(had been few days since I drove it before installing radio). I say this cause I did blow a fuse in process replaced fuse all worked cept jeep wouldn't fire. Checked wiring again all checked good.
After reading this forum on testing the coil when I probe the green wire it is suppose to flash when ignition is being cranked over, mine does not flash so I changed ignition module and coil and same thing. So now I'm wondering if that means my ecm went bad. is there any to check this or should I go ahead and do the nutter bypass that I was plannjng on performing anyway at some point
Again this is my first post on this forum and if I'm not in right place would diff like if u could direct me where to go thanks
cvfd332 is offline
post #550 of 767 Old 08-01-2013, 02:16 PM
AmmitOsiris
Well do you have? YJ or cj ?
AmmitOsiris is offline
post #551 of 767 Old 08-01-2013, 02:28 PM
Renegade82
1982 CJ7
Says 1984 CJ7 under his name. Would'nt ask a wrangler question in a Jeep forum.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #552 of 767 Old 08-01-2013, 02:32 PM
cvfd332
Its a cj 7 I have read some other posts about no spark and I'm thinking its the computer going to do the nutter this weekend
cvfd332 is offline
post #553 of 767 Old 08-01-2013, 02:34 PM
AmmitOsiris
I'm on app, and I have a YJ with the 258 same as late model cjs. Just saying that's why I asked
post #554 of 767 Old 08-01-2013, 02:34 PM
AmmitOsiris
Go to the cj section and ask questions in there they will help you more than i
post #555 of 767 Old 08-01-2013, 02:45 PM
cvfd332
I'm on app as well. Diff will appreciate the help. I'm out of town till Monday but plan on trying to nutter it and do team rush at same time
cvfd332 is offline
Prestolite to teamrush upgrade- Amc 360 v8 2manytoys2 Jeep CJ Forum 13 10-26-2012 01:16 PM
TEAMRUSH Upgrade, Who SELLS PLUG WIRES?? Fjguercio Jeep CJ Forum 14 06-02-2010 09:16 PM
What is a TeamRush upgrade ? tevans59 Jeep CJ Forum 6 01-11-2010 07:02 PM
My TeamRush, Nutter & Weber 32/36 Upgrade for 1985 258 TJTony Jeep CJ Forum 3 01-11-2009 01:17 PM
Teamrush upgrade on 76 CJ5 76silvercj5 Jeep CJ Forum 9 08-26-2008 04:49 PM
