Hydraulic brakes to power brakes question - JeepForum.com
post #1 of 6 Old 02-28-2003, 02:08 AM Thread Starter
Jeep'N 4 Fun
Location: Central California <-- Thanks scottahicks for correcting me on my location. _____(:-)-}-<
I'm new to the jeep world and I just bought a '74 cj5 renagade. Right now it has hydraulic brakes on it and I was wondering if there was a conversion kit to turn it into power brakes. I've looked around and have found nothing yet. Any help will be appreciated. Thanks in advance.
'74 CJ5, 304 V8 5.0L 2BL,
F & R ARB Air Lockers,
Posi-Traction Rear,
3" suspension Lift,
WARN locking hubs,
33X10.5X15 BF goodrich Mud Terrian T/A,
Tow hooks F & R,
KC daylighters,
Dana 30 Front and Dana 44 Rear
and more to come.
Jeep'N 4 Fun is offline
post #2 of 6 Old 03-03-2003, 04:39 PM
AtlantaCJ6
Jeepn 4 fun,
Your Jeep was available with power brakes so it shouldn't be that hard. You need to find a brake booster and bracket (ebay, junkyard, etc...) and cobble things together. I would go ahead and buy a new master cylinder at the same time just to be sure you are working with good parts. You'll also need to connect the booster to a vacuum source on the engine. Its really a very easy swap.
One warning though, when the motor quits so do the power brakes. This is a key thing to remember when you are going downhill on a trail. If you have any carb problems that make your jeep a little prone to stalling on hills you could find yourself running off the trail or into the Jeeps in front of you.
Good Luck,
AtlantaCJ6
AtlantaCJ6 is offline
post #3 of 6 Old 03-03-2003, 04:50 PM
CJ7Jeff
I'll agree with what AtlantaCJ said. There are also places that make brakets for this kind of conversion.
Just for clarification, even power brakes are hydraulic. Hydraulic refers to the brake fluid. Adding power assist just makes them power assisted hydraulic brakes.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #4 of 6 Old 03-03-2003, 05:48 PM
mad_scientist
You may have to change some of your brake lines too, as hydrallic assist brakes have smaller lines (usually). If you go through the trouble of upgrading almost everything, perhaps you should look into simply upgrading with a ford 1/2 ton brakes, as they too fit 15" rims, but have larger pistons and should give you better braking than stock CJ parts.
. . . end transmission . . .
mad_scientist is offline
post #5 of 6 Old 03-05-2003, 08:09 PM
scottahicks
scottahicks's Avatar
this is what you need.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33566
make shure you ask the seller if it comes with all the bracketry?
here is another on complete
good luck I hope this helps
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #6 of 6 Old 03-05-2003, 11:00 PM Thread Starter
Jeep'N 4 Fun
Thanks for all of your help guys. Sorry it took so long for me to reply. You guys certinly know more then I do on this one. Thanks again.
Posi-Traction Rear,
3" suspension Lift,
WARN locking hubs,
Tow hooks F & R,
KC daylighters,
and more to come.
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 11:06 PM
Power steering and boosted brakes question CJ5Freak Jeep CJ Forum 0 07-23-2008 09:13 AM
cj brakes to power brakes worth it? drunkenrich Jeep CJ Forum 21 02-15-2008 03:25 PM
Manual brakes to power brakes theclothman Jeep CJ Forum 17 06-18-2007 05:40 PM
Manual brakes to power brakes. NOVACAIN350 Jeep CJ Forum 4 04-27-2007 09:16 PM
