Hyd Clutch swap, what master cylinder? - JeepForum.com
post #1 of 13 Old 07-29-2007, 12:26 PM Thread Starter
BMac4x4
I got a 78 CJ with a full fiberglass body and a full chevy drive train in it. The 700r4 that it had when i bought it is toast and i'm swapping to a SM465 with a hyd clutch. I know this has been done before so i'm looking to find out what my options are as far as a clutch master cylinder set up goes. Can someone point me in the right direction?
78' CJ7 - nothing origional but the frame. Full fiberglass body, Vortec 350 with a Holly dubble pumper and malory ignition, SM465 trans, NP208 t-case, Chevy 1 ton rear w/ disc brakes and 3/4 ton front, 4.56 gears, 4" lift springs SOA and 2" body, 42" TSLs.
BMac4x4 is offline
post #2 of 13 Old 07-29-2007, 01:08 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
I used a stock XJ Cherokee MC with Wilwood slave. Works good. With a little modification, you can bolt the whole vac booster and pedal assembly in as a unit and have power brakes, too.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 13 Old 07-29-2007, 03:06 PM Thread Starter
BMac4x4
What did you use for a pedal? Stock CJ pedal or one from another vehicle? And how did you connect the rod from the master to the pedal? And yeah power breaks are nice, i have a chevy brake booster in it.
BMac4x4 is offline
post #4 of 13 Old 07-29-2007, 05:16 PM
jayhawkclint
1970 CJ5
I used the whole XJ setup and modified the pedals to fit. There is another thread somewhere around here that I showed some pics, or you can sift through my build thread link in my sig line.
Clutch pedal, modified on top, stock on bottom:
post #5 of 13 Old 07-29-2007, 10:00 PM Thread Starter
BMac4x4
So in your experience with that setup, do you think the stock CJ pedal can also be modified to work with an XJ master cyl?
BMac4x4 is offline
post #6 of 13 Old 07-30-2007, 01:02 AM
jayhawkclint
1970 CJ5
Some people run into trouble there because of rod length/stroke/leverage ratio/etc. With enough fiddling, anything is possible. I just decided the simplest way to make it work was to take a set of components that I knew worked well in one vehicle, and swapped them over to another.
post #7 of 13 Old 07-30-2007, 04:03 PM
slacker92104
slacker92104's Avatar
Does the muncie bellhousing have a mount tab for the slave cyl? If so, I think the ealrly eighties cj's with the four cyl basiclly use a chevy set up. If I'm right it would all bolt in (except for the pedal maybe), but it would all work together just fine.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #8 of 13 Old 07-30-2007, 04:48 PM
jayhawkclint
1970 CJ5
Chevy bell housings use a push-type slave that mounts on a tab. Very plentiful in the junkyards; just about any Chevy truck will work.
post #9 of 13 Old 07-30-2007, 06:03 PM Thread Starter
BMac4x4
I think i'm gonna get a Master from a full size chevy and fab it up to work. I've come up with a couple ideas so far. I figure the Chevy master will work well with the chevy slave so that would be the best route. I don't want to get a master all fabed up and realize that it isn't big enough to fill the slave cyl all the way and the clutch doesn't fully disengage. When its all done i'll post some pics of how it looks and how it worked out.
BMac4x4 is offline
post #10 of 13 Old 07-30-2007, 10:20 PM
supraman1990
supraman1990's Avatar
1980 CJ5
YJ clutch and brake pedals will bolt right in to a CJ and have the HYD clutch tab already on them. Just might have to fiddle with the brake pedal a little.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #11 of 13 Old 07-31-2007, 01:39 AM
slacker92104
It's all about the bore size. Make sure the MC isn't bigger than the slave. Preferrably the would be the same.
post #12 of 13 Old 07-31-2007, 10:13 AM
rnjcrsh
1975 CJ5
Here are some ghetto fab pics at its finest. Maybe you can get some adaptation ideas.
http://webpages.charter.net/xlr8n/pics/jeep/slave2.jpg
http://webpages.charter.net/xlr8n/pics/jeep/slave3.jpg
I have a clutch pedal very similar to the one in the image closest the camera that jayhawkclint posted. You can have it, simply pay shipping.
rnjcrsh is offline
post #13 of 13 Old 08-02-2007, 03:51 PM Thread Starter
BMac4x4
I prefer to call that redneck engineering! I'm gonna have a little of that on the master cyl rod where it connects the pedal. Thanks for the offer on the pedal but i'm gonna use the CJ one. I'll post some pics when its done tomorrow.
BMac4x4 is offline
Clutch Master Cylinder phil77 Jeep CJ Forum 8 04-09-2010 08:38 PM
clutch: different bore size for master and slave cylinder kercher Jeep CJ Forum 0 10-09-2009 10:24 AM
Help, Clutch master cylinder problem my80cj5 Jeep CJ Forum 4 07-06-2006 09:17 AM
Clutch Master Cylinder Aphelion79 Jeep CJ Forum 2 06-28-2006 11:09 AM
What Clutch Master Cylinder ? Scrambler82 Jeep CJ Forum 3 03-20-2003 03:31 PM
