Quantcast Hutch's 1985 CJ7 Frame Off Rebuild - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hutch's 1985 CJ7 Frame Off Rebuild
Old 08-02-2009, 05:41 PM   #76
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
The red is bringing back memories of the red one that left this weekend!
cb
CertifiableJeep website
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
ORANGE JEEP CLUB #41
certifiablejeep is offline   Reply With Quote
Old 08-02-2009, 08:22 PM   #77
hold24
hold24's Avatar
1978 CJ7
cb
Did you sell one this weekend? Any regrets yet? I'm thinking of selling one
1978 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac and factory 8-track....
hold24 is offline   Reply With Quote
Old 08-03-2009, 05:36 AM   #78
certifiablejeep
Bicentennial Nickel
1976 CJ5
Didn't sell one, but I did finish one up for a customer.
Basically it left this weekend... and then I didn't have a Jeep to work on, so I had to hang the border in the babies room... not quite the same thing.
cb
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
Old 08-03-2009, 06:29 AM   #79
Ziptie2k2
Absolutely BEAUTIFUL!!
1977 - CJ7.......1979 CJ7.......1981 - CJ8.......1986 CJ7 Cant get enough!
Originally Posted by 442Wrangler View Post
where do you believe you go when you die?
Originally Posted by sanchagrins View Post
you go in the ground, duh.....
Ziptie2k2 is offline   Reply With Quote
Old 08-03-2009, 10:12 AM   #80
JoonHoss
1968 C101
Originally Posted by pwa_fcva View Post
Hey Hutch... looks great!! Don't know how much it matters, but I think you have the sway bar backwards.
Yep-I was thinking the same thing!
otherwise- looks great! can't wait to see more
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 08-03-2009, 10:14 AM   #81
cshutchinson
Box Man
cshutchinson's Avatar
Yeah, I've got to figure that sway bar out, at the time, beer logic indicated that was the only way it would fit.
1985 CJ7 / SBC 383 / D300 / NV3550 / 35 SSRs
Hutch's 1985 CJ7 SBC 383 Frame Up Rebuild
cshutchinson is offline   Reply With Quote
Old 08-03-2009, 10:18 AM   #82
JoonHoss
1968 C101
just take it back off, and flip it around left-to-right. if it's stock, you'll need longer ends to put it back in the 'correct' pre-lift condition.
Hoss
Old 08-16-2009, 06:00 PM   #83
cshutchinson
Box Man
Here are some updated pictures: The wiring is finally done!
Old 08-16-2009, 06:03 PM   #84
cshutchinson
Box Man
More pics:
Please note the tailgate carpet piece does not match perfectly, I had to have it made since Nifty hates me... It will work ok.
NV 3550 Transmission and D300 (D300 Stick bent to the right to clear trans shifter with clocking)
Old 08-16-2009, 06:07 PM   #85
cshutchinson
Box Man
Here is my to do list... It seems to grow longer the more I get done.
coil / distributor wire
tail lights harness at front
water temp sender
oil pressure sender
carburator
throttle cable
air cleaner
spark plug wires
spare tire
install rad. fan wiring circuit
radiator hoses
heater core hoses
drive shafts pictures / measure
rotate sway bar
battery cable to remote cutoff to starter
tighten body bolts
tighten suspension bolts
paint rocker panels / tube step
power steering lines
fender support rods
lower fender support rods
install hood
hood support rod
fuel vent line
paint differential covers / install
transfer case vent line
differential vent lines
transmission fluid
transfer case fluid
differential fluid
master cylinder bench bleed
brake fluid (DOT 5)
bleed breaks
power steering fluid
radiator coolant
battery charger wiring test
install battery
install winch
install drive shafts
test run
install roll cage add on kit
install doors
test fit hard top
paint hardtop
final fit hard top
Old 08-16-2009, 06:54 PM   #86
cshutchinson
Box Man
Do you guys know the specs for an AGR gear box to a Chevy power steering pump? I guess i need to have a supply and return cable made. Any tips would be appreciated.
Old 08-16-2009, 08:59 PM   #87
mjfitz99
Your build looks really nice! Thanks for posting the nice pictures of a beautiful project!
mjfitz99 is offline   Reply With Quote
Old 08-16-2009, 09:09 PM   #88
DirtyDevin
1983 CJ7
Wow man. That is incredible. Nice build.
DirtyDevin is offline   Reply With Quote
Old 08-17-2009, 06:14 AM   #89
cjsteven
1981 CJ7
I installed a new chevy 350 with new power steering pump and was able to reuse the original suply and return lines (on a stock cj power steering box)
cjsteven is offline   Reply With Quote
Old 08-17-2009, 06:52 AM   #90
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Absolutely beautiful! Gotta be one of the nicest engine bays I've seen. After seeing the pics of the wiring harness work, I guess it's time for me to open that box from Painless and get started on mine...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Glock Forum
