Quantcast Hutch's 1985 CJ7 Frame Off Rebuild - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hutch's 1985 CJ7 Frame Off Rebuild
Old 03-25-2008, 07:31 PM   #31
cshutchinson
Box Man
cshutchinson's Avatar
Originally Posted by sdhutch View Post
mr. hutchinson,my mom said she dated a guy from sc.can i call you daddy.lol.looks great.steve hutchinson
I didn't know I had an old girlfriend in Cali. Is she hot? You guys have to stop with the Mr. stuff. Just call me HUTCH.
cshutchinson is offline   Reply With Quote
Old 03-27-2008, 03:07 PM   #32
cshutchinson
Box Man
D300
Well, I was getting the transfer case cleaned up today. I really hadn't looked too closely at it before, but it was covered in oil and dirt and more oil and dirt. There was silicon all over it and no gaskets . I guess I have to at least open it up and install the gaskets. I hadn't really planned on that. Any tips will be appreciated. Anything else I should check while I am in there?
1985 CJ7 / SBC 383 / D300 / NV3550 / 35 SSRs
Hutch's 1985 CJ7 SBC 383 Frame Up Rebuild
Old 03-27-2008, 04:02 PM   #33
Fatman
2008 CJ7
Mr. H ... Kidding
Hutch,
I just got through doing the same thing for the same reasons:
http://www.jeepforum.com/forum/f8/d300-seals-521371/
Let me know if I can help in any way.
Dave
Fatman is offline   Reply With Quote
Old 03-27-2008, 04:56 PM   #34
tsujeeper
I just did the same thing as well. It's pretty easy, I didn't have any instructions, just kind of disassembled and reassembled. I was also 3 sheets to the wind when I did it so that tells ya how simple it really is. The worst part was after I got done I stepped(stumbled) back, looked at it, and thought "Wow, I just spent like 5 hours to replace 4 or 5 gaskets."
79CJ7/401/NP435/D300/D44/14BFF in progress! Check out my build thread... http://www.jeepforum.com/forum/f8/project-chaos-523991/
tsujeeper is offline   Reply With Quote
Old 03-27-2008, 06:56 PM   #35
cshutchinson
Box Man
Well, this project was a good reason to buy an arbor press, I have always wished I had one. I found a great deal on one tonight. I got a rebuild kit for the 300 from Novak that will be here tomorrow, so the weekend should be fun. Thanks for the info guys. I am sure I will have questions.
Old 03-30-2008, 06:35 PM   #36
cshutchinson
Box Man
Well, 4 beers later I have the Dana 300 completely torn apart and the parts and pieces nicely grouped together as they came out.
I only had one problem. One of the driveshaft knuckle nuts is kind messed up. I guess I beat on it too hard with not enough threads engaged Oh well, I am glad it was the nut and not the shaft. Thank goodness it was hardened.
Anyway, not one single gasket on this entire assembly. Seems strange to me. I will post some pics for my own reference later as it came apart. The more I drank the fewer pictures I took
It was almost fun and not nearly as hard as I thought it would be. I got to use my new bearing press twice So guys, does it go together as easy as it came apart? Did you guys check the play with a dial indicator when you put it back together? I guess I have to acquire a dial indicator and base.
Old 03-30-2008, 06:40 PM   #37
bsakal
Junior Member
bsakal's Avatar
That project is looking sweet, I'm drooling
'88 YJ 4.0 AX15 NP231; '97 ZJ; '69 Charger SE 383; '66 Newport 383
bsakal is offline   Reply With Quote
Old 03-30-2008, 07:42 PM   #38
Fatman
2008 CJ7
Hutch,
We need to get you motivated, I have to have mine done for my trip to Hilton Head at the end of June.
Do you need my build log so you can move faster? We need to meet up when you're done, if not before.
If you need to order parts, I have a guy in GA that has given me Outstanding prices on parts, I usally order over $1000 plus at a time but still.
Old 03-30-2008, 08:01 PM   #39
cshutchinson
Box Man
Fatman,
I was going to suggest that we meet up at some point. I was going to wait until I really hit something I couldn't figure out Anyway, I got the transmission bolted up on Friday... I hope the cross member will bolt up...
Here are some pics of the D300 tear down:
Old 03-30-2008, 08:09 PM   #40
Fatman
2008 CJ7
Saaweet! Are you going to have to reach behind to shift that NV3550? That sucker is long.
Awesome look'n job.
so is the Chevelle a 72?
Old 03-30-2008, 08:13 PM   #41
cshutchinson
Box Man
Awesome look'n job.
Man, I hope not. That would suck have to drive with one hand behind my back . The Chevelle is a 71 with a 'built' 454, Ford 9", 3 speed. It really needs a restoration.
So it seems you guys painted the 300 after you put it back together. I guess I can start reassembly tomorrow. I don't think I am going to replace the flux capacitor / torrington bearing. I have no idea how to get it out of the inside of the shaft.
Old 03-30-2008, 08:16 PM   #42
Mr.Crowley
1980 CJ7
wow that is a long tranny..Start lookin into a cv driveshaft
now would be a good time to add a sight tube for the gear oil in it..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Old 03-30-2008, 08:20 PM   #43
cshutchinson
Box Man
Front or rear or both? What will I need to change on the transfer case to accomodate? Just the yokes?
Old 03-30-2008, 08:39 PM   #44
Mr.Crowley
1980 CJ7
the rear deffinately..if you go with a xj style drive shaft you can use the front yoke from an xj also..It bolts right in..
[QUOTE=Me]
:hahaha: yj
Old 03-31-2008, 10:12 AM   #45
pepsi_man
1974 CJ5
Hay, GREAT JOB! Did you powder coat everything or what did you use?
I have a long way to go to get to where you are. Trying to figure out how to upload pics. Help!
pepsi_man is offline   Reply With Quote
Glock Forum
