Hutch's 1985 CJ7 Frame Off Rebuild
#16 | |
Looks like I'm behind both of you (Fatman and cshutchinson)... is that Powder Coated after the bead blast? I've been rebuilding my axles first... I plan on cutting out the cancer on the frame and starting on it. I was thinking of POR15 and then Chassis Coat... but whatever you did, it looks great!
AWESOME!!! http://plaza.ufl.edu/rt826jw/scrambler/cj8.htm
#17 |
Bicentennial Nickel
clouby, I just saw your pics of your Scrambly and it seems like you took quite a whack to the firewall when you removed the tub.
The only question I have is why didn't you have some people help you lift it off instead of pull it off? I guess the good news is that if it was that weak and bent easily, it is good to know that up front and you can fix it now. cb |
#18 | |
Box Man
#19 |
Very nice.
85 CJ7,Clifford equipped 258,TBI,RE4.5,35" Claws,Aussie lockers,8.8 rear. Blue Jeep Club Member #134 http://www.youtube.com/watch?v=1tQ_AE6iqis http://www.freedomoffroad.org |
#20 |
Nice job and set up. So you going to wheel it?
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed. |
#21 |
Nice Jeep, is that a six into one header that you have there?
Reason that I am asking is that I ran into a guy with a 74 Javelin the other day with a 232 six into one and it sounded sweet, like a V8.
Presnt Jeep(s). 91 Wrangler 4.0 H.O. 3" lift and 32" tires. 86 CJ-7 2.5 (Yuck!) totally stock and rust free, factory Dana 44 in the rear. |
#22 |
Box Man
Here is an updated picture guys. I just finished building the 383. The block is a 1999 Vortec 5.7L out of a 99 Chevy pickup. Dang, it took me forever.... But, I learned a heck of a lot about building a motor; not that I knew much to start with.
My goal is to have this thing done by the end of summer. Maybe it will happen. Advance Adapters is holding up the transmission / bell housing by constantly sending incorrect parts and leaving out other essential ones, but they are easy to work with and happy to correct the problems. I can't believe it has already been a year since my last post. Where does time go.... ![]() ![]() Thanks for looking. Last edited by cshutchinson; 03-23-2008 at 05:03 PM.. Reason: Add Image |
#23 |
Wow. Nice rig and hella' nice shop. Your floor grew some personality over the year also i see.
1978 CJ7 I6, 2.5" dik cepek spring lift, 0.5" shackle lift, Cooper Discoverer S/T 33's, 1.25" Wheel Spacers. http://i255.photobucket.com/albums/hh157/kconnor123/CIMG1504.jpg?t=1221918667 Whats Next: Wide track swap, winch, new seats, eventually a 4.0 mpi swap from a 90's cherokee or wrangler. |
#24 |
What size tires did you decide to go with?
#25 |
Box Man
They are 35 x 12.5 Super Swamper radials on 15 x 10 MTs.
I actually moved the project to the garage beside my house. The other shop is used for my business and too much stuff was going on around my never ending project. |
#26 |
Can I live with you?
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad. |
#27 |
Do you plan on doing any body lift at all? Will just the Rubicon Express 4.5" kit fit 35s?
#28 |
Box Man
#29 |
Mr. Hutchinson take a look at my tub thread, I just set the tub for the last time.
Should give you an idea of what the RE 4.5 and a 1 inch BL will sit at. Your build is looking good, cant wait to see ot progress. Love the shop!
#30 |
mr. hutchinson,my mom said she dated a guy from sc.can i call you daddy.lol.looks great.steve hutchinson
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
