hub or axle shaft joint? - JeepForum.com
post #1 of 5 Old 07-29-2010, 12:50 PM Thread Starter
79jeepincj7
1979 CJ7
Last night wheelin heard a loud snap/pop sound when stuck trying to get up over something while articulating. After getting past that now it pops every few seconds. Once i got to a clearing is turned hard right and backed up and it goes snap.... snap..... snap.... someone said it might be a blown hub which i have never heard but to me it sounds and feels like the u joint in the axle shaft. Any thoughts? What happens if you blow a hub? Being that plastic piece it wouldnt sound like this would it?
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #2 of 5 Old 07-29-2010, 01:23 PM
AFjeepMan
sounds like a u-joint. try to wiggle the u-joint around, there should be no play if it's good.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 5 Old 07-29-2010, 01:24 PM
gojeepin
1983 CJ7
The front hubs are steel but the hub lockouts are a combination of parts.
The internals of the hub lockouts are not all plastic. The parts that actually apply force are metal but they can still break.
If it's the lockout, you should be able to see a cracked housing... replacement is easy since it bolts to the outside of the hub, however you'll need snap ring pliers.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 5 Old 07-29-2010, 03:20 PM
crzdmnky
1978 CJ5
Dont need any snap ring plyers, lol. Just need a small flat head screwdriver. But sounds like something is wrong lol. See if it still makes the noise after unlocking the hub. Run diagnostic on it, test out things, all that fun stuff. We can give you ideas, but only you know the exact sounds, and where it was coming from.
crzdmnky is offline
post #5 of 5 Old 07-29-2010, 03:55 PM
kakai81
Sounds like a good time to pull it apart and use quality Spicer u-joints.
kakai81 is offline
axle , axle shaft , hubs , lockouts , stub shaft , ujoint
D30 - axle shaft hits lower ball joint stud... 243 Jeep CJ Forum 25 12-21-2011 05:19 AM
Drive shaft u-joint replacement VACJ7 Jeep CJ Forum 5 05-26-2009 08:32 AM
Steering shaft U-joint part??? SuB8HaVeN Jeep CJ Forum 13 04-08-2008 01:10 PM
Axle shaft U joint replacement HELP! xj89 Jeep CJ Forum 25 11-14-2007 06:53 AM
Where can I get a new steering shaft joint?? '83Laredo Jeep CJ Forum 4 05-16-2005 09:28 AM
