HOWTO: AMC 20 OEM TRAC-LOK dismount/mount - Page 2 - JeepForum.com
post #16 of 34 Old 06-27-2011, 11:08 AM
benullman
1981 CJ7
No welding the spiders for me. I wants a regular trac-lock for the streets. I understand the whole spooled/welded thing. I was just curious if the dana 44 scout track lock was the same or if there was another procedure because the spiders have some cracked teeth and need rebuilding
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #17 of 34 Old 06-27-2011, 11:35 AM
82JeepCJ7
1982 CJ7
I loved my welded up crap-lok so much that when I built my Dana 60 rear, I put a full spool in it. Sure makes the Jeep track strait going down the road. It barks a little on tight corners but not too bad.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #18 of 34 Old 06-27-2011, 12:09 PM Thread Starter
stgil
1982 CJ7
Ben
If you're talking about a DANA 44 of CJ, it looks like the same than a AMC 20 look at >>> HERE <<<
So same tip/hack
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is online now
post #19 of 34 Old 06-27-2011, 01:03 PM
JeepHammer
Running On Empty...
1973 CJ5
Ben
Depends on year. There were some changes, but I don't know exactly what changes or what years those changes came into effect.
Spline count on axles might be different for the side gears also...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #20 of 34 Old 06-27-2011, 05:45 PM
FLynes
1976 CJ5
Originally Posted by JeepHammer View Post
"Track Lock" is AMC's version of a 'Posi', like 'Posi-Trac' was GM's.
Even though they used the same differentials from the same companies, they gave them different 'Marketing' names...
Mopar also used the name Trac-Lok; I had a Dodge Ram with 4.10:1 Trac-Lok Dana 80.
Dana Spicer was the manufacturer of the Trac-Lok and came up with the name, if anyone cares.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #21 of 34 Old 06-28-2011, 03:15 AM Thread Starter
stgil
1982 CJ7
Checking runout...
The runout of the cage must be checked:
and must NOT exceed 0.002" !!! (0.05mm) Otherwise the backlash can't be set
Mine does not exceed 0.03mm (~+0.001")
stgil is online now
post #22 of 34 Old 08-29-2011, 11:49 AM
DUX4LIFE
1977 CJ7
Old post I know but I wanted to say thanks for making the picture tutorial. It convinced me I could do it myself and it was much simpler than I believed. One question though, originally I only had very little resistance with the old clutch packs (one hand could hold the axle shaft and my teenage son could turn the other). Now I need to use a crowbar on each end of the axle shaft but I can still get it to break free, How much resistance should I have?
A Nation of Sheep Breeds a Government of Wolves!
DUX4LIFE is offline
post #23 of 34 Old 08-30-2011, 02:29 AM Thread Starter
stgil
1982 CJ7
You're Welcome!
This is quite normal ! (mine too was hard to turn but not with a crowbar )
By the way, do you have put some oil on each washer of the new clutch pack ?
Regards,
Gilles
stgil is online now
post #24 of 34 Old 01-15-2015, 09:49 AM
bobbysjeep
1984 CJ8
Thanks for this tread stgil! If I mark the ring gear, bearing caps, etc, and just replace the friction plates and spider gears then reassemble with everything in the same orientation and have no carrier runout. Do i still have to re-shim the backlash? Considering tackling myself and have never set gears. I would be reusing the old bearings, gears, and carrier housing.
bobbysjeep is offline
post #25 of 34 Old 01-15-2015, 10:36 AM Thread Starter
stgil
1982 CJ7
Hello,
As far as I know, you can do that by marking EVERYTHING and put together at the same place...
FYI: removing carrier's bearing is not needed for this operation : keep them safe and clean. Keep in mind IF you do that anyway, there is good luck you destroy the bearing during remove operation (VERY VERY tight!)
I've a post about this operation but it's in french for the moment... but google translation is your friend: >>> HERE <<<
Regards,
Gilles
stgil is online now
post #26 of 34 Old 03-16-2015, 06:58 AM
77amc
1981 FSJ Cherokee
Good morning.
I've been doing searches and searches about the 20 rear ends and have a '81 Cherokee w/t. Got under there and scraped and found the "BB" code (supposedly a 3.31/trac-lok) but don't see the 'other' cross pin looking thing going through the carrier.
The vehicle is at a buds shop and can't just go out back and take another look.
SO, are there any other ways to tell if it's a trac-lok?
Inside of the spiders that slide on the axles themselves, it looks like a thin 'notched' crown and don't know if these are an 'upgrade/revision' from amc/jeep.
I'll try and upload pics to my imageshack and post what I have.
Thanks E
77amc is offline
post #27 of 34 Old 03-16-2015, 07:39 AM
77amc
1981 FSJ Cherokee
Here's a couple pics.. Can you notice the little 'notches' in the inner sides of the spider gears?
E
http://imageshack.com/a/img908/2449/ozPHoK.jpg
http://imageshack.com/a/img540/6105/td1GkB.jpg
http://imageshack.com/a/img909/9063/KX5QGz.jpg
77amc is offline
post #28 of 34 Old 03-16-2015, 07:57 AM
Fourtrail
1974 CJ6
Originally Posted by 77amc View Post
Good morning.
Thanks E
You won't have the 'other' cross pin looking thing in your axle. The fsj model 20 axles are not of the weak 2 piece design like the cj's. The part you do not have was a thrust block to keep the 2 piece axles in place.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #29 of 34 Old 03-16-2015, 07:57 PM
77amc
1981 FSJ Cherokee
Well PRAISE GOD!!
Do you know how many (somewhat) useless threads I had to read to get to THIS TRUTH?
Even most all the 'images' that I googled don't even elude to this..
I don't even remember reading it in Wiki.
You just saved me hours and even weeks of work. (but, was kinda wanting to know how this 14bolt was going to 'feel' like though...)
Now, I've looked into rebuild 'kits' and don't want some goober selling me the wrong parts.
Who might be called that WILL know what I need for a re-fresh? I really don't want to pay for just a NAME brand, just good quality
and by the way I'm planning on using the Jeep, should last for another 20+yrs. (unless it poops out)
Thanks again guys.
Errol
77amc is offline
post #30 of 34 Old 05-26-2015, 08:37 AM
matt1980
1980 CJ5
I will be replacing the clutch disks in my rear end soon and have looked at all the pictures, my question is that I see a feeler guage being used, looks like it is headed for the back side of one of the spider gears. Is it just being used to get the washer out or is there a clearance that is being checked there? I also see a 50mm od measurement on the washers being used, anyone know what size washer they are or will I be doing some grinder work on a slightly larger washer, or does it have to be exactly 50mm? I have 3.08 gears, does the ring gear need to come off? Will be the first time I will be doing work inside the diff so anything I need to look out for? Thank you all for your help and great pictures.
matt1980 is offline
HOWTO steering column switch stgil Jeep CJ Forum 2 11-10-2010 11:34 AM
wide trac front d30 vs narrow trac quad haro504 Jeep CJ Forum 14 09-17-2010 07:52 PM
How to measure wide trac/narrow trac cyclic17 Jeep CJ Forum 1 05-23-2005 01:22 PM
Howto tell which Tranny? Hale Jeep CJ Forum 3 12-17-2003 10:36 PM
? about narrow-trac and wide-trac scottahicks Jeep CJ Forum 10 10-21-2002 09:10 AM
