Quantcast Howell TBI install - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Howell TBI install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-08-2008, 07:46 PM   #31
gmakra
As far as your check eng light it will probably go out after 20 or so miles. Every time you disconnect power to the computer the ECM will lose its learned program and have to relearn your eng parameters. This is also true if you adjust your idle air or change you fuel pressure at you regulator.
gmakra is offline   Reply With Quote
Old 02-03-2010, 05:45 AM   #32
markr1001
1987 YJ Wrangler
Originally Posted by Fatman View Post
It's purple:
#1
do you have a clearer version of this pic?
markr1001 is offline   Reply With Quote
Old 02-03-2010, 11:20 AM   #33
Fatman
2008 CJ7
Due to a hard drive failure a couple of years ago, I don't have the original.
Do you need something explained ?
Fatman is offline   Reply With Quote
Old 02-03-2010, 06:47 PM   #34
markr1001
1987 YJ Wrangler
basically im trying to figure out how to wire up my HEI distributor to my 4.3TBI harness to make it control the spark, it cant use anything from the original jeep harness. and i will weld the vacuum advance stuff to make it not work...
Old 02-03-2010, 06:48 PM   #35
markr1001
1987 YJ Wrangler
and cant find a diagram to explain what i need to do, my HEI has the coil in the cap if that matters
Old 02-04-2010, 09:30 AM   #36
CSP
Go to www.binderplanet.com and then to their EFI forums. Read the stickies posted by USN_Bill (I think that's the name). You'll find wiring diagrams for the PCM to control spark. You will need a different ignition module (GM 7-pin) since you have the HEI with the coil in the cap. It's not difficult at all if your wiring harness is already setup for it.
CSP is offline   Reply With Quote
Old 02-04-2010, 09:09 PM   #37
markr1001
1987 YJ Wrangler
OMFG that is the best site ever... all my answers have been answered... that is sweet thankyou
Glock Forum
