Howell TBI/ CTO valve question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Howell TBI/ CTO valve question
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 10-28-2005, 02:02 PM   #1
CJ7 Vette
hey everyone,
I have an 84 CJ7 w/258 in the middle of a fresh engine swap. I am installing the howell tbi this weekend and heard I need a CTO switch from a 90 wrangler to install correctly....is that right? thanks! Dave
ps-great site!!!
84 CJ7 new 258,Howell TBI, Borla header/exhaust, clutch, repainted engine compartment,frame and most of undercarriage,jks discos and a host of other new stuff under the hood :)
update: no rust, new floors, stripped, primed, filled, blocked, and repainted with PPG Concept Garnet Metallic. Hardtop freshly painted, all trim painted in black metallic with a bit of flatener mixed in. New seats, carpet, console, roll bar pad, seat belts,dash, flares, windshield, seals, tire carrier and more!
CJ7 Vette is offline   Reply With Quote Quick reply to this message
Unread 10-28-2005, 05:57 PM   #2
jadams68
Not exactly true. The howell kit calls for a dual-CTO valve... switch...same thing.
Late model CJ's had duals, but most of our heeps had single-CTO valves.
Here's what a double one looks like, you can buy them for $65 at a stealership.
http://www.bustedjeep.com/projects/tbi/cto.jpg
I used the single CTO-valve that was on my motor....it's totally fine and everything will run well.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 06:54 PM   #3
CaptainNick
1987 YJ Wrangler
I did, but I didn't see anything about bypassing the CTO, just using a single CTO.
I guess a better question is what is the minimum amount of vacuum routing needed to run a Howell TBI? I know the distributor needs ported vacuum, and the brake booster needs manifold vacuum. Can I just bypass everything else for a few days--cap it off?
CaptainNick is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 08:14 PM   #4
CSP
Is this for the California legal kit?
CSP is online now   Reply With Quote Quick reply to this message
Unread 05-23-2015, 08:34 PM   #5
CaptainNick
1987 YJ Wrangler
It is. I've ordered the dual-CTO from RockAuto, but it's going to be a few days, so I'm looking for a solution to get everything running.
Unread 05-24-2015, 02:49 AM   #6
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
IIRC, the CTO only supplies the EGR and vapor purge signal on a Howell setup. You can run without either of those.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
