Howell "44" flash - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Howell "44" flash
Income tax season is upon us. We got what u needRough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 09-12-2013, 09:27 PM   #1
kjonesie
1983 CJ7
Howell "44" flash
My check engine light came on today and it was a code 44 (lean O2 sensor). Could this be because I just installed a cold air intake. I always thought the filter I had was restricting air flow. Will the computer "learn" and fix this?
kjonesie is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 07:20 AM   #2
gmakra
Probably nothing to do with the cold air intake. Check your wiring and see if you have a lose connection otherwise its probably time to replace the O-2 sensor.
The cold air intake is negated by the heated manifold so you wont see any real performance gains.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 09-13-2013, 09:08 PM   #3
kjonesie
1983 CJ7
I dont have a heated manifold
Unread 09-14-2013, 04:02 AM   #4
Dougyfreshh
02 sensor is going bad causing a lean code
Dougyfreshh is online now   Reply With Quote Quick reply to this message
Unread 09-14-2013, 06:07 AM   #5
gmakra
Why dont you have a heated manifold?
I know it sounds counter productive to a cold air charge however it ready does help keep the fuel in suspension in the manifold.
Unread 09-19-2013, 10:17 PM   #6
kjonesie
1983 CJ7
I replaced the O2 sensor and that seemed to solve my problem. Are Offenhauser intakes heated?
Unread 09-20-2013, 05:58 AM   #7
gmakra
If you have the heater hoses hooked up to the manifold yes you have a heated manifold.
The Offy and Cliford manifolds do not have provisions for the electric heater.
Unread 09-20-2013, 06:22 AM   #8
kjonesie
1983 CJ7
I don't have the heater hoses hooked up either.
