-   -   Howell "44" flash (http://www.jeepforum.com/forum/f8/howell-44-flash-1580465/)
kjonesie 09-12-2013 08:27 PM
Howell "44" flash
My check engine light came on today and it was a code 44 (lean O2 sensor). Could this be because I just installed a cold air intake. I always thought the filter I had was restricting air flow. Will the computer "learn" and fix this?
gmakra 09-13-2013 06:20 AM
Probably nothing to do with the cold air intake. Check your wiring and see if you have a lose connection otherwise its probably time to replace the O-2 sensor.
The cold air intake is negated by the heated manifold so you wont see any real performance gains.
kjonesie 09-13-2013 08:08 PM
I dont have a heated manifold
Dougyfreshh 09-14-2013 03:02 AM
02 sensor is going bad causing a lean code
gmakra 09-14-2013 05:07 AM
Why dont you have a heated manifold?
I know it sounds counter productive to a cold air charge however it ready does help keep the fuel in suspension in the manifold.
kjonesie 09-19-2013 09:17 PM
I replaced the O2 sensor and that seemed to solve my problem. Are Offenhauser intakes heated?
gmakra 09-20-2013 04:58 AM
If you have the heater hoses hooked up to the manifold yes you have a heated manifold.
The Offy and Cliford manifolds do not have provisions for the electric heater.
kjonesie 09-20-2013 05:22 AM
I don't have the heater hoses hooked up either.
The time now is 10:18 PM.
