How to test locking hubs???????? - JeepForum.com
post #1 of 15 Old 05-23-2011, 05:59 PM Thread Starter
truckshop21
1981 CJ5
So I was bored the other day and jacked up the front of my jeep and put the hubs in 4wd mode and spun the tires but the drive shaft didnt spin. Does this mean both hubs are bad or is something broken in axle?
truckshop21 is offline
post #2 of 15 Old 05-23-2011, 06:05 PM
Fourtrail
1974 CJ6
When you spun the tire, did the other one spin the opposite direction? You would need to hold one in place and spin the other to get the drive shaft to spin.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 15 Old 05-23-2011, 10:45 PM Thread Starter
truckshop21
1981 CJ5
no the other tire didnt move
post #4 of 15 Old 05-24-2011, 08:16 AM
scso81
1980 CJ7
Put the front end on jack stands. (for safety) lock the t-case in 4x4. lock in both hubs. Spin the drivers tire. You should see the u-joint in the knuckle spinning. If if is not then it is not locked in. If it is you should see the other tire spinning. If if is not, check the u-joint in the passengers side knuckle and see if it is turning without the tire. If the passengers u-joint is turning but the tire is not, then the passengers tire is not locked in.
Let me know what happens.
scso81 is offline
post #5 of 15 Old 05-24-2011, 08:39 AM Thread Starter
truckshop21
1981 CJ5
awesome directions headed to my warehouse now let you know asap and thanks again
post #6 of 15 Old 05-24-2011, 09:14 AM
lucdog
lucdog's Avatar
1980 CJ5
Just to make sure the hubs are locked. Clockwise locks them, CCW to unlock. This is on the 6 bolt hubs. Fairly certain 5 bolt hubs are the same.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 15 Old 05-24-2011, 09:35 AM
scso81
1980 CJ7
there should be marks on there to let you know if it is locked or not.
scso81 is offline
post #8 of 15 Old 05-24-2011, 09:39 AM
scso81
1980 CJ7
i have the 5 bolt (1983) hubs. It has a 2 and a 4 on it. I have to turn mine clockwise from the 2 to the 4 to lock them in. most manual hubs are the same.
scso81 is offline
post #9 of 15 Old 05-24-2011, 11:13 AM Thread Starter
truckshop21
1981 CJ5
Alright both wheels spin when I followed your directions
post #10 of 15 Old 05-24-2011, 11:15 AM
scso81
1980 CJ7
so when you spin one wheel the other is spinning in the opposite direction?
scso81 is offline
post #11 of 15 Old 05-24-2011, 11:37 AM
jumbojeepman
1976 CJ7
Here's another method. Put the jeep in 4wd, engine off, transmission in gear. Jack up one front tire, lock in both front hubs. You shouldn't be able to turn the tire. If you can, something is wrong.
jumbojeepman is offline
post #12 of 15 Old 05-24-2011, 12:34 PM Thread Starter
truckshop21
1981 CJ5
yup!!!!
post #13 of 15 Old 05-24-2011, 02:57 PM
CJunk
Or- don't jack it up or anything. Lock the hub, reach under and spin the axle ujoint by hand. If you can't move it, the hubs are locked.
CJunk is offline
post #14 of 15 Old 05-24-2011, 08:59 PM
Cutlass327
1978 CJ5
Or the fun way, lock in the hubs, put it 4wd on a gravel or dirt area, put the Trans in gear, and jump on it. See how many wheels are throwing dirt/mud/gravel
Rick
Cutlass327 is offline
post #15 of 15 Old 05-24-2011, 10:51 PM
lucdog
lucdog's Avatar
1980 CJ5
Either what Cutlass said. or if the warehouse has a gravel lot, chain the jeep to something solid, 4 wheel low, lock the front hubs. if theres a weak link , you will find it, and if the brake are applied, just a little bi both front wheels may turn.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
