How to tell a bad steering shaft???
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I have a 1982 Jeep CJ7 with a 2 inch lift. When I had 30 inch tires the steering was ok. (a little play) But now that I put 32 inch tires on, it pulls hard to the left sometimes. Then to correct, I have to turn the wheel right a good 1/4 turn, this cause the CJ to jerk really hard to the right. Like I said, this doesn't happen all the time, so I am thinking its the steering shaft??? Any help would be great.
#2 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Have someone inside turn the steering wheel side to side while you watch right under the brake master at that column U-joint, then next watch down at the bottom by the box at that joint.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#3 |
Thanks! I will do when I get home. Have any idea what to look at next, if the shaft seem to check out?
#4 |
Parts Locator
I would look at how much the steering box moves when you turn the steering wheel to the right. I would check the bolts that hold the box to the frame and make sure that they are not loose. If the steering box moves a lot I would get a steering box brace.
84 CJ7 Northstar V8 Pictures of it, http://s56.photobucket.com/albums/g198/cjinpa/odds%20n%20ends/?start=all 91 YJ Renegade, Daily Driver since 1991. 97 TJ daily driver. 2011 F250 King Ranch. Jeeps that I am currently parting out; 91 YJ Renegade 5spd 1990 YJ auto 1991 YJ 4cyl 5 spd Just my luck I was born in the land of plenty now there ain't enough. |
#5 | |
Off Road Forever
#6 |
Thanks for all your help. I will look at everything mentioned. I check out the tierods and the balljoints about a 5,000 ago, I replaced one tierod, the others were ok. (Might be my problem) I got an alignment right after. It just became a problem the day after I got my new tires, I had the shop balance them a secound time. The only patern I have seen is, it happens about a 1/4 mile after I hit a bump. Other than that, it happens when ever. Do you think it is caused by the 2 inch increase in tire size?
#7 |
What kind of tires did you get?
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44 |
#8 |
BFG Mud-Terrain 32x11.5R15
#9 |
Those tires should be fine. It sounds like an alignment problem to me. Good luck,
Brady
#10 | |
Off Road Forever
I run BFG 33x9.5 Muds and can take my hand off the steering at highway speeds and it tracks perfect. No 'tacking into the wind' idea at all. Now alignment issues.... If they messed that, it will do like you say. You can set it in the driveway, I have always done mine and my tire wear is perfect. You find the seam in the tires and measure across the front of the tires seam to seam, then do it again on the back side of the tires as high up as you can reach seam to seam. The front measurement should be a little less than 1/4" shorter than the back measurement. Someone in another thread just mentioned wheel bearings. If they are loose, it will jump around. You jack it up and see if the tire feels sloppy on it's bearings by grabbing it and wiggling it.
#11 |
If this started after the tires were installed, you might try switching them front to rear to eliminate any questions. Might also check the springs to see if they were inadvertently damaged by a jack while at the tire shop. Otherwise, a full inspection is in order as Mike mentioned above. The larger footprint of the tire may be causing various front end components to move more than they did before.
#12 |
What kind of lift do you have?
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes. Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA, |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
