How to seperate the steering column - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > How to seperate the steering column
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 06-08-2011, 02:50 PM   #1
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I have the complete steering system loose (top to bottom). My question is how do you seperate the column from the steering shaft to get them out?
Thanks in advance
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote
Unread 06-08-2011, 03:47 PM   #2
Patter
1981 CJ5
Thanks in advance
Are the bolts that hold the two together all the way out?
There is a pinch bolt that sets in a radiused groove on some. If the bolt is not completely out. It won't slide off.
Shot in the dark. ??
Good luck.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline   Reply With Quote
Unread 06-08-2011, 03:49 PM   #3
trailhead2004
1980 CJ7
Did you loosen the connection at the steering box? If yes, you might just have some rust holding it together. You might want to try some Kroil or Liquid Wrench overnight and/or a few taps with a hammer.
HTH.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline   Reply With Quote
Unread 06-08-2011, 04:27 PM   #4
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I have remove all the bracketsunder the dash. The bracket on the frame mount is all free. The entire cloumn is floating in the firewall. I have removed the copler bolt and made sure the clamp is loose. So where is this pinch bolt that sets in a radiused groove?
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
Unread 06-08-2011, 04:34 PM   #5
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Sorry I forgot, the steering box is still fully attached to the shaft. Does that need to be removed first?
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
Unread 06-08-2011, 04:46 PM   #6
Patter
1981 CJ5
Slikric.
I actually just googled that. Mine was not that way. Just tryin to help out.
Good luck
Unread 06-08-2011, 05:58 PM   #7
Coiz
Coiz's Avatar
1979 CJ7
The bolt that attaches the column shaft to the intermediate shaft needs to be completely removed as it catches a groove on the end of the column shaft. After that it is pry it apart and tap/pull it out.
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 06-08-2011, 06:07 PM   #8
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
That by the manual is called the copler bolt and yes it is removed and the clamp even spread. It still woill not move
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
Unread 06-08-2011, 06:15 PM   #9
Coiz
Coiz's Avatar
1979 CJ7
Get a bigger hammer! Can you get a pry bar between the end of the column and the top of the intermediate shaft?
Mike
My build thread
Unread 06-08-2011, 06:18 PM   #10
ejschmitt
I have used a pickle fork on this before to go around the shaft onto the u-joint mount, then tap it out with a deadblow or hammer
ejschmitt is offline   Reply With Quote
Unread 02-17-2012, 08:07 PM   #11
TOBYWON
Guys, I'm stuck trying to get my column back into the shaft. It goes right in, but I cant get the pinch bolt back through the coupler! I tried to use a C clamp to squeeze the coupler together enough to allow the pinch bolt to go back through, but no joy. Any tricks on how to do this? HELP!
"... God demonstrates his own love for us in this: While we were still sinners, Christ died for us." Rom 5:8 (NIV)
/l , [____],
l---L--OlllllllO-
()_) ()_)----)_)
{{{84' CJ7 RENEGADE / 258 I6 / Nuttered, HEI Dizzy, MC2150 (eBay) w/Manual Choke, MSD 6AL Ignition, Engine Totally Rebuilt in 2010}}}
TOBYWON is offline   Reply With Quote
Unread 02-17-2012, 08:11 PM   #12
ejschmitt
Which side are you having a problem with? Are you sure it is on with the correct orientation? The shaft will have a flat spot or chamfered spot for the bolt to go through, if this is not aligned the bolt will not go through.
Unread 02-17-2012, 08:39 PM   #13
mopar408
1974 CJ5
Rick, IIRC if you have the steering coupler shaft loose at where the bell goes onto the steering box and the whole column loose at the dash/firewall you could just bring the whole mess back out thru the cab in one big piece. When you had it laying on your workbench it'd be easy.
Just a thought.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline   Reply With Quote
Unread 02-17-2012, 08:47 PM   #14
TOBYWON
Yeah, I tried to slot the pinch bolt through from either side, but I can't squeeze the tips of the coupler together enough to make a straight hole. Did I pry it too far apart during extraction? what could I use to squeeze those tips together just a bit?
/l , [____],
l---L--OlllllllO-
()_) ()_)----)_)
Unread 02-17-2012, 09:13 PM   #15
TOBYWON
Here's what I'm dealing with.
/l , [____],
l---L--OlllllllO-
()_) ()_)----)_)
