how to replace light bulbs in auto column gear shift indicator - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > how to replace light bulbs in auto column gear shift indicator
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 01-26-2006, 12:02 PM   #1
tankcj
tankcj's Avatar
Anyone remove the (PRND21) gear indicator on the column of their CJ? I need to replace the light bulb and paint the tab (that lines up with the gear you're in). The service manual just says to remove the clips with a punch...but it kinda looks like they're in a little opening just behind the indicator and not easy to get at.
Thanks!
tankcj is offline   Reply With Quote Quick reply to this message
Unread 01-26-2006, 12:45 PM   #2
jeepskate
Yup, you gotta remove the clips. I think I ended up using a small screwdriver and a pick.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote Quick reply to this message
Unread 01-26-2006, 03:51 PM   #3
tankcj
tankcj's Avatar
Ok...do you remeber if you just popped 'em out or just pushed 'em down...or?
Unread 01-26-2006, 04:40 PM   #4
jeepskate
Pushed them down and pulled them out. I think there was only one clip that had to be removed, then the housing just unclips from the other clip(s).
Unread 04-11-2015, 12:11 PM   #5
swh492005
could someone please help me, I need to change the bulb on the shift indicator of my 1981 CJ7, could anyone please help me out with a picture or step by step instructions....It will be greatly appreciated....
swh492005 is offline   Reply With Quote Quick reply to this message
