How to remove steering wheel - JeepForum.com
post #1 of 3 Old 04-07-2011, 06:39 AM Thread Starter
Burgettw
for a 74 cj5 how do you remove steering wheel I have a puller but there is only the center shaft that is threaded no 3 holes for the bolts...is there any tricks out there? I beat the crap out of wheel and it is not moving that I can tell.
Burgettw is offline
post #2 of 3 Old 04-09-2011, 04:57 PM
nielsencc86
1972 CJ5
I had to cut mine off. I notched ther collar that slides around the steering shaft. Luckily I was replacing it otherwise it would be very tough. I tried everything including using ratchet straps coming off the roll bar to try and pull it to no avail!
nielsencc86 is offline
post #3 of 3 Old 04-09-2011, 06:16 PM
lanecj5
1980 CJ5
its pressed on a splined shaft and should press off with a 2 jaw gear puller not a regular steering wheel puller.Sorry maybe splined is the wrong word it may be a square key stock in a slot
lanecj5 is offline
help! - Remove Power Steering Gear Box Matusel3 Jeep CJ Forum 4 06-27-2010 08:44 PM
How to remove 4 wheel driver shifter bfmalone81 Jeep CJ Forum 10 05-19-2009 10:24 AM
No Wheel/No Steal System for Grant Steering wheel Ridettu02 Jeep CJ Forum 12 11-11-2008 12:44 AM
Is it possible to remove a steering wheel without a puller? part.changer Jeep CJ Forum 17 06-15-2007 08:21 PM
How do you remove the Steering column shroud Mikey Jeep CJ Forum 5 11-25-2002 03:36 PM
