How to remove e-brake??? - JeepForum.com
post #1 of 8 Old 09-25-2011, 08:00 PM Thread Starter
eddy2324
Well I guess the first question is do I have to remove the emergency brake to get the body off?
If so, how in the heck do I do it?
eddy2324 is offline
post #2 of 8 Old 09-25-2011, 08:13 PM
FLynes
1976 CJ5
Yes, you do. I just did it with my CJ. If you look underneath, you'll see where the e-brake cable is connected to the e-brake assembly. It was easier for me to take the whole e-brake assembly off and then disconnect the cable.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #3 of 8 Old 09-27-2011, 08:12 PM Thread Starter
eddy2324
ok so i took the assemble off but not sure how to get the cable off. any help?
eddy2324 is offline
post #4 of 8 Old 09-27-2011, 08:17 PM
jcalhoon84
1980 CJ5
I unhooked the cable underneath where it splits and then used vice grips to get enough slack to pull the cable out of the groove of the pedal assembly.
jcalhoon84 is offline
post #5 of 8 Old 09-27-2011, 08:45 PM
mopar346
If it's the style I am thinking of, you can fully depress the pedal (tell it sad stories) then clamp the cable with vise grips, release the pedal and it will move back free of the cable. This will allow enough slack to work it out of the hook, then release the vise grips and slide the cable out the back. The challenge is putting it back in, I have been successful with sliding it in the back of the pedal assembly, take one pair of vise grips and clamp it at the end of the cable pull it as far as you can and then use another pair of vise grips to clamp it at the base to keep it from moving back, remove the first pair of vise grips and return it to the hook in the pedal.
If it is a different style, I just wasted your time. Post a picture if you can.
Careful your character's showing
mopar346 is offline
post #6 of 8 Old 09-27-2011, 10:02 PM
jcalhoon84
1980 CJ5
Agreed!
post #7 of 8 Old 09-28-2011, 12:35 PM Thread Starter
eddy2324
i will try that, if i can't get it i will post a pic. thanks for the help!
eddy2324 is offline
post #8 of 8 Old 09-28-2011, 02:57 PM
bconrad5150
2010 JK Wrangler
I just backed the nuts all the way off the cable under the body. The cable came out through the frame and is still attached to my body.
bconrad5150 is offline
How to remove parking brake cable? mknherhappy Jeep CJ Forum 9 08-14-2011 09:54 AM
How to remove front brake hoses? (I searched) Turtle71 Jeep CJ Forum 4 04-14-2011 12:54 PM
Hood hinges? Do I really have to remove the the dash and all to remove them? HHICJ7 Jeep CJ Forum 12 11-24-2009 02:02 AM
How can I remove the brake disque on a D30 ? patcj7 Jeep CJ Forum 14 01-19-2009 06:58 PM
how to remove front brake calliper 78_levi_cj5 Jeep CJ Forum 3 03-19-2006 08:11 PM
