How to remove the dash? - JeepForum.com
post #1 of 2 Old 06-22-2013, 08:38 AM Thread Starter
steelhead9
How do you get the dash completely out of the jeep? Do you have to remove the steering column? Is there a link someone can't point me to for more information?
I've taken all the bolts out and moved the dash around before to do wiring under the dash, replace speakers, put in new gauges, etc. but I've never gotten it complely out of the Jeep.
steelhead9 is offline
post #2 of 2 Old 06-22-2013, 08:48 AM
John Strenk
John Strenk's Avatar
1976 CJ5
No Just the steering wheel needs to be removed.. The column can just be dropped down if needed.
You could remove the column and leave the wheel attached if you find that easier...
You cn pull the dash out with the wiring attached. You just need to unbolt the bulkhead connector from the fire wall. Youcan disconnect all the plugs on the brake switch and stuff.
Label them all first.
John Strenk is offline
