How to paint stainless steel? - JeepForum.com
post #1 of 14 Old 12-02-2008, 03:46 PM Thread Starter
stephens_cj5
1981 CJ5
I need to paint a few stainless steel pieces, how do I do it?
My going in plan is to scuff it up with some 220 grit, then prime it followed by the top coat and clear. I need to know if this will work from those who know or have done it.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline
post #2 of 14 Old 12-02-2008, 03:53 PM
keith460
Jeep. There's Only One
keith460's Avatar
You can paint any steel, whether it's stainless or carbon based. Prep is everything, sandblast, sanding to rough up the surface slightly so the paint can adhere to the surface.
keith460 is offline
post #3 of 14 Old 12-02-2008, 04:01 PM
1997_Sport
you can paint you may have to use a type of solvent like 5717s so first gets surface rust and acid away then some echi-primer then regular primer then sand it then paint then clear so there will be no rust. (i go to a tech school and just learned and used that stuff my self in class)
1997_Sport is offline
post #4 of 14 Old 12-02-2008, 04:48 PM
NewdRiver_
I painted my polished hinges black. Glass bead-blasted them, sanded the surface to get it smoother, used etching primer over the bare metal then top coated. Works awesome.
NewdRiver_ is offline
post #5 of 14 Old 12-02-2008, 06:10 PM
ScotZ
American to the Bone
ScotZ's Avatar
Etching primer is the key to painting stainless
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #6 of 14 Old 12-02-2008, 06:40 PM
neals80
1980 CJ7
SST can not be painted...and have it last anytime
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #7 of 14 Old 12-02-2008, 06:58 PM
bjf498
bjf498's Avatar
1983 CJ7
Stainless steel can be painted or powder coated, just use an oil based paint, and a good primer you will be fine. I painted some stainless hood hinges when I got my jeep 4 years ago, it still looks great.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #8 of 14 Old 12-02-2008, 08:53 PM Thread Starter
stephens_cj5
1981 CJ5
Are most auto paints such as PPG oil based?
post #9 of 14 Old 12-02-2008, 08:57 PM
zachblamercj7
self-etching primer and paint
1986 CJ-7 258 Dana 30 front Dana 44 rear Dana 300 T-case
zachblamercj7 is offline
post #10 of 14 Old 12-02-2008, 09:06 PM
jksull
My be unrelated to the post but what does self-etching primer have in it to etch SS.
My experience with etchers, they seem to have a acid that does a good job on carbon steel and rust.
Would just like to know
jksull is offline
post #11 of 14 Old 12-03-2008, 05:47 AM
1997_Sport
now adays most are becomeing water based because of voc's but there are still some oil based out there just not as commen as the water based will be
post #12 of 14 Old 12-03-2008, 11:16 AM
bjf498
bjf498's Avatar
1983 CJ7
You can get some oil based paint an autozone most cans say what type it is. No need to get ppg.
bjf498 is offline
post #13 of 14 Old 12-03-2008, 11:17 AM Thread Starter
stephens_cj5
1981 CJ5
I was hoping it would not get to this but it looks like I'm going to powdercoat it. I could paint it myself and HOPE for the best but I am not to excited about the possibility of having to break the dash down because the paint is flaking/chipping off. I found a powdercoat that is really close in color to what the jeep will be.
Thanks to all those who chimed in.
post #14 of 14 Old 12-04-2008, 01:24 PM
bjf498
bjf498's Avatar
1983 CJ7
powder coating will be the best choice. But normally around here people want to know the cheapest way they can do it.
bjf498 is offline
CJ Stainless steel bolt kit dddkkk Jeep CJ Forum 20 10-15-2013 10:03 AM
Stainless steel rust? Whats up with that? Floridazed Jeep CJ Forum 11 07-28-2008 07:47 PM
Stainless Steel CJs NewdRiver_ Jeep CJ Forum 12 06-14-2008 06:04 PM
Looking for stainless steel brake lines Hale Jeep CJ Forum 6 01-08-2004 08:24 PM
Stainless steel headers Jeepcd79 Jeep CJ Forum 0 08-13-2002 12:25 PM
