How to - Nutter Bypass - Page 8 - JeepForum.com
post #106 of 443 Old 06-02-2009, 08:12 PM
jon1371usmc
I have recently performed the bypass on my Jeep. I would like to eliminate all unnecessary tubes, smog equipment, etc..., that I no longer need to have due to bypassing the computer. Is there a thread out there showing what can be removed? I want to clean up the engine compartment to the bare necessities.
Thanks
Jon
jon1371usmc is offline
post #107 of 443 Old 06-02-2009, 09:13 PM
ET48
Thanks
Jon
I plan to do the same really soon, I am just gonna start it, and start pulling. If it dies or doesn't start back up, I am leaving it. I think that is alittle easier sometimes.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #108 of 443 Old 06-02-2009, 09:15 PM
ET48
Thanks
Jon
This guy has a pretty good website for determining what can be pulled and what can't be. http://home.sprynet.com/~dale02/
ET48
ET48 is offline
post #109 of 443 Old 06-02-2009, 09:35 PM
jon1371usmc
Does anyone have any pictures of their engine bay/ carberator after they removed all the useless hoses, vacuum tubes, etc.... I would like to see what worked for you.
Jon
post #110 of 443 Old 06-03-2009, 05:26 AM
Mike Romain
If you folks read through this thread, it will tell you exactly what to keep for a good runner. All the vacuum hookups are covered.
To repeat myself, you need the PCV system including the charcoal canister (gas tank vent eh), the ported vacuum lines for the CTO to turn on the canister and the distributor advance, the EGR valve for a better high speed burn (cam is designed for an EGR) and the air filter flaps to prevent the carb from becoming a block of ice if you live cold.
Mike
Mike Romain is offline
post #111 of 443 Old 06-03-2009, 06:15 PM
jon1371usmc
Is it okay to remove the sol-vac setup.
post #112 of 443 Old 06-04-2009, 05:08 AM
Mike Romain
Yes, although some folks keep it and wire it to a switch so they have an instant fast idle at the flick of a switch.
Mike
post #113 of 443 Old 06-04-2009, 10:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yep, it's nice if you have AC or an converted AC to Air Compressor setup. Great if you have a wench also.
John Strenk is offline
post #114 of 443 Old 06-06-2009, 05:55 PM
jon1371usmc
Why would you need the fast idle? Is it mainly for off-roading, or for hauling/pulling?
post #115 of 443 Old 06-07-2009, 03:02 PM
Mike Romain
Winching, boosting, AC, Auto....
Mike
post #116 of 443 Old 06-27-2009, 04:40 AM
stoneywaves
To everyone who has done this
Is everyone getting the same results as mike romain? 20+ miles, great drivability at all angles. If so Mike I want your results. I just rebuilt my engine and tranny and carb (when I say I - I mean I paid someone for their services) and am getting average 12.5 which is aggravating as all hell
Thanks. 1983 cj7 258. Everything is stock except for a mild "RV" cam by elgin pro stock e-1122-p. My timing is set at 15 btdc.
stoneywaves is offline
post #117 of 443 Old 08-02-2009, 05:51 PM
only1chip
1983 CJ7
Thanks soooooo much!
I just performed this bypass on my '83 CJ7 and it worked like a champ. Actually due to my 4 cyl engine (150CID) with Carter YF carb, all I had to do was wire the two (orange & violet) wires from the ignition to the distributor (roughly steps 6-11). I don't have the stepper motor on the carb, so that was mute.
After 6 months of issues with my jeep, replaced the computer!, purchased rebuilt carb, new distributor, etc. But this was the ticket! Truth be told, it probably needed most of the other parts, except the new computer...
A few details the may help future CJers: after replacing my carb, at first the jeep ran great, then over the next 40-50 miles the operation deteriorated, especially in 3rd and 4th gear. It acted like it was running out of gas (believe me I know that symptom - broken gas gauge!). I could feather the peddle or even NASCAR the jeep back an forth to get it to fire correctly - but it would never have the correct power in those gears - interestingly it seem to run pretty well in first and second. This mod. and it runs great. And yes I live in GA, where after 25 years we're exempt from all emissions testing.
Thanks to the all the people who have posted here, this board was the key to getting my jeep running again!
only1chip is offline
post #118 of 443 Old 08-02-2009, 07:25 PM
Mr-Rock
Just an FYI,
Here in CT we have to go thru emissions every two years. After doing the nutter bypass, here are my "Pass" readings.
-HC(PPM), CO(%), NOx (PPM), RPM
Limit- 160, 3.09, 4000
Actual 160, 1.88, 444, 1949
I have since done the Team Rush upgrade hoping it helps with the Hydrocarbons. Guess I'll find that out in a couple of years!
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares.
Mr-Rock is offline
post #119 of 443 Old 09-06-2009, 02:47 PM
vertdog
Hey Mike or Luckycheesehead...
I am in process of nuttering and have 2 questions. Anyone chime in with answers. First, where can you get new connectors for the igniton module? I just wired the new orange and purple straight to module. Second, my CTO switch only has 2 vacum fittings, the diagrams show 4. Do I just use t's to run my lines. Thanks in advance!
vertdog is offline
post #120 of 443 Old 09-06-2009, 07:11 PM
lopezzi
1983 CJ7
vertdog,
Check out this thread, mine also only has the 2 port CTO and this is how mine is setup. Read through the thread, the guys were really helpful. There is also pics on it that show you how to do it and I have pics of my setup with it all done.
http://www.jeepforum.com/forum/f8/nu...r-34-a-544678/
1983 CJ7 258, Weber 34/34, Nuttered, Rushed, 4" Rancho Lift, 33" Bridgestone Duelers, 10k lbs Winch.
lopezzi is offline
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
What's a Nutter Bypass? ollietonk Jeep CJ Forum 11 04-05-2005 08:50 PM
