#91 | |
timing
Standing on the passenger side of the jeep looking at the distributor.. do I need to rotate the distributor clock wise or counter clockwise (everyone says towards the block and that confuses the heck outta me)
And about how much in general to get it close.... quarter turn.. half.. just a touch ??
#92 | |
1985 CJ-7, Chevy 350, NP435 trans, LoMax 4-1 Twin sticked Dana 300, Dana 44's ARB, Spool, 4.56, 36" Swampers, Warn XD9000i. 1990 YJ Weber 36/36, CRT Distributor, 31" AT's 1993 XJ 1999 Cummins Ram 3500 Baltimore 4 Wheelers |
#93 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You need a timing light. You can sort of get it close with a vacuum gauge. You turn it until you get the highest vacuum, then back it off an inch of vacuum. I really experienced mechanic may be able to set it by ear close, but engines are deceiving...
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#94 |
timing light
No problem,
I can get a timing light. I just wanted to have it somewhat close before starting it up and running it. I'll go to the local auto store and check out the loaner. |
#95 |
Off Road Forever
It won't be off that much and should start up in the old position. Just don't run it long like that.
#96 |
FYI for anyone doing this in the future, before starting the bypass adjust the timeing to 8' btdc. thats what i did and it started right up after doing the bypass. I still had problems keeping it running until I dialed in the carb but it only took a matter of minutes before she was purring like a kitten!
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares. |
#97 | |
Off Road Forever
#98 | |
Thanks
#99 |
why didn't I set timing first..
DOH !!!
Now you tell me !!! ... I am just about done.. I figured I had had enough for the night and will finish it tommorrow.. I purchased a timing light so it shouldn't be too much more tommorrow to finish up. I went ahead and removed all of the purge valve system as well. I had a few extra stuff to remove with the cruise control above the washer and coolant tanks. But was no biggie. I went ahead and took off a ton of vaccum crap and removed the purge air system as well. The only thing I feel like I am not certain on doing right was resetting the carb mixture screws.... I decided to try it at one and a half turns out from all the way seated.. should this be close to first start it.. or do I need to loosen them another turn? Thanks guys... I guess I will find out how well I did tommorrow evening. |
#100 | |
Off Road Forever
I start at 5 turns out on both screws 'with' the stepper motor pins set as mentioned earlier, with their shoulder 1/8" from the back wall. Once running, I get the timing set, then I fine tune the mix for 'best lean idle'. To do that I start screwing the pins in, in 1/4 turn stages each, then give it a rev to set the flow, the turn them another 1/4 turn then give it a rev to set the flow, then.... until that last 1/4 turn starts a stumble happening. At that point, I back them off about 1/4 to 1/8 a turn. I 'will' have to reset the idle speed usually more than once to keep it under 700 rpm while doing this.
#102 |
Question... When I do this, can I just pull the computer out from under the dash too? Or does it need to stay for some reason?
#103 |
Off Road Forever
The computer can be tossed.
#104 |
I know it might be a stupid question, but do I need to do the nutter bypass if I have replaced the carb with a weber 32-36. I still have some problems with it running right, especially with the choke activating when cold. I also have a bunch of vacuum lines running around and don't know which ones to keep and which ones to get rid of.
I have an 82 CJ-5 |
#105 | |
Off Road Forever
If you have a computer in there, it has now gone into limp home mode which clamps down on the timing advance so yes, it should be made gone. To see if the computer is there, check the ignition module plug. The 4 wire plug will have a purple wire that terminates at the plug 'with' a computer in the system, with no computer, the purple wire continues on at that plug.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
