#61 | ||
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Dale did a great site on the 258, here is his links: http://home.sprynet.com/~dale02/ http://home.sprynet.com/~dale02/vac-egr.htm http://home.sprynet.com/~dale02/vac-tac.htm http://home.sprynet.com/~dale02/vac-mcu.htm
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#62 |
Mike, if you do not have the guts for the stock air fliter will the set up still work w/out the TVS thingy. ![]() If I don't have a SOL-VAC vacuum how would I hook this up/to what? Meaning I have the SOL-Vac but all I have routed is the CTO, dizzy & the canister hook up. Oh, I cleaned my air fliter can & then cleaned out the pcv valve w/ spray brake cleaner, so far no oil in the a-filter can. The pcv was clogged some what. P.S. I understand about the move, we are gonna move again in May. ![]()
*MY CJ IS YOUR yJ's DADDY* Project CJ8 Build Gallery <----Click CJ8 Build Thread<---- Click |
#63 | ||
Off Road Forever
I have heard reports of the vacuum/electric part of the sol vac, if everything stock is left, will still work to bump the throttle up for an automatic or AC. You could wire the electric for the AC also easily if needed. Some folks have added a fused 12 volt switch to this for a manual fast idle
#64 |
Thanks, didn't think of that w/the electric for the A/C (it's Peaches Jeep and she want's her A/C running for summer). Yes, it does take a little longer in teh morning/winter but no biggie.
Thanks for the info.
#65 |
Junior Member
On an 86 CJ7 you're supposed to cut the orange and purple wires in the loom before the firewall and splice them to the ignition module. Are you supposed to cut another orange wire and splice it together with the orange distributer wire running to the ignition module?
#66 | |
Off Road Forever
I am of the firm opinion the job is best done by running two all new twisted together wires directly from the orange and purple at the ignition module to the orange and purple at the distributor rather than mess inside the loom. Having two new wires twisted together like the factory wires are twisted together for RF filtering is the best. Otherwise you have this lone purple wire that can pick up all kinds of stray pulses.
#67 | |
Junior Member
#68 |
Junior Member
One more thing, what's the best way to keep the wires from untwisting?
#69 | |
Off Road Forever
#70 |
Wow!!! Great thread and great info!!!! I will be doing this bypass tomorrow.
Couple of questions though: I have an 86' CJ-7 with the 258, with a Motorcraft 2100 carb for more power. I have trouble keeping freeway speeds up. Will this help by taking the ignition system out of limp mode? Is there anything else that this bypass will effect? Thanks and again, GREAT WORK!!!!! ![]()
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#71 | |
Off Road Forever
If I was going to use a V8 carb, I would want headers and a high flow exhaust so it doesn't just bog it out. That Carter-Weber BBD you had on there was the better carb in my opinion. Tuned and nutttered, the BBD pulls mine to 75 mph in 3rd and 4th buries the speedo big time with no urge to test 5th for top end... It will also purr up sand pit/ravine walls at 400 rpm without a chug. Also gives 21 mpg... I know I lose highway top end fast when my carb is set too rich. I have played with the high speed mix to see. That 2100 can have different jets put in it I think that may make it better for a 6... That said, getting it out of limp mode should help a lot, it frees up the timing advance for one thing. It also basically shuts down several miles of those vacuum hoses, well in limp mode, not much is working anyway. Here is a good site for seeing what is what: http://home.sprynet.com/~dale02/ http://home.sprynet.com/~dale02/wire-sml.htm
#72 | |
I have it running good now, it just seems like there is no top end. Which I can tell that the engine is leaning out when it throttles up. (Must be the limp mode limiting the advance of the spark, thus making it run leaner as more throttle is applied) I have the right jets for the engine and carb, but I have a problem with the engine leaning out when higher RPMs are reached as stated above. I am just hoping that freeing the timing advance up will get rid of the leaning out of the engine. My plan is to "Nutter bypass" my jeep, and remove all the old EC harness and ECM computer. Then reset the timing and reset the carb. I'll let you know how it turns out tomorrow. I added a cherry bomb to the exhaust, got rid of the cat, and kept the old manifold. Should flow enough I think.
#73 |
OIIIIO
Just curious how you know it is leaning out at full throttle conditions. If it is, wouldn't that indicate you don't have the correct main jets? How did you determine you have the correct jets? What altitude are you at? ( not familiar with OHIO topography...)
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20. 1986 CJ10-A SD-33 Diesel/727/np208 1971 800B with 345/T-19 88' Comanche, 4.0L F.I., 5 spd. |
#74 | |
![]() So the jets are perfect for the engine, just that upper RPM range that is giving me fits. I sit at 1,000-2,000 feet range. I don't know exactly......
#75 |
Well,
I got finished with the jeep around 9:00pm and just now are getting around the laptop. The bypass went well and smooth. Basically just two wires to run for me, and adjust the timing and carb. I took it for a short test drive and it made alot of difference between 2,000rpm and 4,000rpm!!! I was doing burnouts all over the place I have yet to get the adjustment perfect on the carb but it seems to run really well. Everytime I floor it, it will cutout and pick right up. I am gonna run the jeep to work and pull the plugs to see how they look. My guess is that I am running a little rich right now. Thanks for the info and it really helped.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
