#46 | ||
.You just grab the pins and pull or push. Mine is very stiff. I have found three positions. In, middle, out.
#47 |
Actually, there are no positions. Upon working mine more it is apparent that it can be in any position. The setting Mike just suggested seems to be a mid setting.
#48 |
It would seem that you can plug the stepper motor plug back in so it looks, umm, won't burn the plug. Thoughts ?
#49 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The nutter just takes the computer out of the ignition loop.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#50 | |
Off Road Forever
That mid setting has the shoulder of the pins sticking about 1/8" from the back wall when it is back together.
#51 |
so I read this entire thread and cant wait to get started on this. Seems easy and effective. After the Nutter is done, exactly what wiring can be removed from the CJ...everything connected to the ECM and including the ECM itself??
#52 |
...also, does doing the Nutter mean installing a manual choke if the ECM is removed?
#53 | |
Off Road Forever
#54 | |
#55 |
OIIIIO
Twoleos,
May I make the suggestion to not cut any wires when you start removing them? I found that you can simply unplug them and the whole emissions harnes will come out. You will need to add one wire for the choke. I believe this is what you are referring to when you asked if the choke is affected. You can unplug things one at a time, and test drive, and if you like it then you can remove the harness intact, and if you ever sell the Jeep (not that you ever would), the next guy can hook back up if needed.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20. 1986 CJ10-A SD-33 Diesel/727/np208 1971 800B with 345/T-19 88' Comanche, 4.0L F.I., 5 spd. |
#56 | |
1985 Jeep CJ-7 Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage. USMC 1999-2004 Semper Fi! Torchmate CNC Plasma Table Build / Projects |
#57 |
#58 |
Off Road Forever
I don't think luckycheesehead will mind I am going to add a quickie on the vacuum lines after the Nutter for the Carter BBD here.
Here is what makes a decent runner that will pass emissions in Canada: The PCV system including the canister and CTO valve and the EGR maybe as well as a ported line to the distributor. I also want the air cleaner lines working to prevent carb icing, emissions wants it for faster warm up. On the Stock Carter BBD or Carter-Weber BBD like mine, the drivers side back corner nipple goes to the air filter TAC (hot air flaps). The big driver's side port on the bottom goes to the power brakes. The center back big one goes to the PCV with a T fitting for the canister purge. If you have a solenoid on this line, toss it as a recall, only leave the T for the canister purge. Back passenger side to choke pull off. The valve cover side center goes to the distributor. It 'can' T for the CTO feed 'or'.. The front drivers side corner one goes to the CTO valve. From the CTO, a line goes to the canister purge signal 'and/or' one can be fed off this purge line to the air filter TVS and from there to the EGR. Some folks feed the CTO to the TVS and then split off the line coming from this to make the canister and EGR lines. Everything else is pretty much trash.
#59 | |
Jeep # 1 - 1947 CJ2a - Restoration in progress...very slow progress Jeep # 2 -1983 CJ7 - 31x10.5R15 Pro Comp Extreme mt's - 4.0 HO head - MC2100 Jeep # 3 - 1990 Cherokee - 4.0, AW4, dana 30 HP, dana 35 -31x10.5 R15 mud terrains, 2" PNP lift.....Gone to the crusher Jeep # 4 - 1999 wj stock and still pretty |
#60 |
Mike, maybe a 360* pic w/the air cleaner on/off so some can get a visual of the lines and how they are hooked up. I'm sure this will help clear up a lot of questions in this area.
Jim
*MY CJ IS YOUR yJ's DADDY* Project CJ8 Build Gallery <----Click CJ8 Build Thread<---- Click |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
