How to - Nutter Bypass - Page 26 - JeepForum.com
 1Likes
post #376 of 447 Old 06-23-2014, 10:27 AM
dn101009
Ok, since I am taking the whole harness out. The black, orange, and purple on the distributor can be spliced to the black, orange and Purple on the ICM. The green from the ICM needs to be spliced into the trigger wire at the coil?
Why do the wires need to be twisted together?
Thanks sorry for the newbie questions. Been several years since I have really messed with the cj's.
dn101009 is offline
post #377 of 447 Old 06-23-2014, 11:04 AM
Mike Romain
The green is the coil negative wire. This controls when the coil fires.
You twist the orange and purple wires together so radio frequency (RF) emissions don't interfere with the pulses in the wires. Radios, alternators, spark plugs, cell telephones, all these things can send out radio waves that could interfere with a clean ignition signal and cause a miss in the engine.
I used insulated type SOW cable (commonly called 'cab tire' cable, covers anything) on a lot of them for this reason. The SOW wire has twisted wires inside with a paper and silk thread capacitor wrapped with them. All for RF insulation. Probably overkill, but I had the wire on hand from installing mobile data computers in delivery vehicles that were real touchy about RF.
Stock, AMC just twisted them, no issues.
Mike
Mike Romain is offline
post #378 of 447 Old 06-23-2014, 05:28 PM
Baconj81
Ok so let me get this straight. I have the Weber carb. So all I have to do is splice orange and purple wires from distributor to ICM and reset timing to 8* btdc? Do I have to do anything with vacuum hoses or anything else?
Baconj81 is offline
post #379 of 447 Old 06-23-2014, 07:18 PM
Mike Romain
Not unless you want to. None of the emissions things will work except the gas tank vent ( canister), PCV and EGR but they can be left in place.
Mike
post #380 of 447 Old 06-28-2014, 08:15 PM
dn101009
Hey guys. I am finally finishing up my bypass. What is the base timing for a 150 amc and are the notches 1 or 2 degrees.
dn101009 is offline
post #381 of 447 Old 06-29-2014, 05:07 AM
Mike Romain
Notches are 2° starting with +2 on the far right. Don't know the base timing for a 150, sorry.
Mike
post #382 of 447 Old 08-25-2014, 11:09 PM
Tuckerpap
What happened to my nutter
I have tried the nutter twice and still haven't got it right. When it comes time to set the timing I start the engine and it will only run for 3 manye 4 seconds then it just dies. No way I can keep it running long enough to time it. What am I doing wrong?
Tuckerpap is offline
post #383 of 447 Old 08-25-2014, 11:16 PM
Tuckerpap
I have tried it twice with no luck
post #384 of 447 Old 08-26-2014, 05:34 AM
Mike Romain
It should run at the old timing setting. Was it running well before you started this? Did it sit long enough for the gas filter to have dried out and plugged up? ( modern fuel gums up filters and seizes float needles if it evaporates away.)
Are you getting fuel to the carb?
Be aware that the hold down bolt for the distributor is the ignition ground path so if it is too loose or rusty you can have issues. Lots of folks ground that black wire coming from the distributor to be sure of a good ground.
Mike
post #385 of 447 Old 08-26-2014, 01:11 PM
sickcj978
Was it cold when u went to start it cause when u do the nutter u loose your electric choke u need to try to keep it running till it's warm check make sure the choke is closing and opening
sickcj978 is offline
post #386 of 447 Old 08-26-2014, 01:25 PM
Mike Romain
You really should read the how to nutter bypass. You most certainly do Not lose your choke. All the nutter is is hooking the ICM direct to the distributor like a 1980 engine.
Mike
post #387 of 447 Old 08-27-2014, 11:31 AM
sickcj978
I did read it but the po did the nutter to my cj there are a lot of things missing I just assumed it was part of it I did a manual choke any way there was a lot of the harness was just sitting on my intake not connected I did all manual Gages too oh and I did have trouble cause the po did not time it after doing the nutter so when I checked the timing and timed it I had to get it warm to keep it running
post #388 of 447 Old 08-27-2014, 12:38 PM
Mike Romain
Sounds more like a hacked job then a nuttered job. Done right they still pass the emissions sniffer and 'can' pass a visual if really needed. Everything a 1980 CJ had still works properly. Just the extra emissions and timing control ECU is bypassed.
Mike
post #389 of 447 Old 10-02-2014, 06:41 PM
GACOACH
Stepper Motor & Metering pins
Went to do the "nutter" to my 1990 Wrangler 4.2. Will not idle, only runs when above 1500rpm, has a mis or stutter at most any rpm but is much worse at low rpm. Anyway, I decided to remove the stepper motor to see what these metering pins look like. I removed it and no pins. So i get a mirror and light(you cannot see it unless you were a contortionist weighing 75 pounds) to see what was inside where I had just removed the stepper motor.There are three holes aligned vertically. One hole was blocked or what i thought was the back of the "pin". I took a small allen wrench and while looking down the throat of the carb, pushed the pin in from the back. What came into the carb was not a metering pin like in the pictures. What I got was a piece of metal, kinda like the head of a large straight pin, round, and like the body that was once connected broke off.WTF to do now?
John in Chatsworth, GA
GACOACH is offline
post #390 of 447 Old 10-02-2014, 07:39 PM
Mike Romain
It was running Ok before you tried the nutter???
Mike
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
What's a Nutter Bypass? ollietonk Jeep CJ Forum 11 04-05-2005 08:50 PM
