How to - Nutter Bypass - Page 24 - JeepForum.com
post #346 of 446 Old 07-27-2013, 07:13 PM
sickcj978
so i went to do the nutter and come to find out the PO did it all ready so i started looking at my harness and turned out it was hacked to death and the only connectors left were two temp sensors. i pulled the harness back and started removing the loom and found out some dumb *** spliced all kinds of **** and used duct tape to splice,dumb ***. Well turns out that my ecm was disconnected too so i pulled it all then checked my timing and it was at 4 degrees so i bumped it up to 8 and it runs awesome thanks so much for all the help this site rocks love all the great help and awesome rigs.
sickcj978 is offline
post #347 of 446 Old 07-28-2013, 05:41 AM
86cj74.2L
86cj74.2L's Avatar
That was a factory splice and factory duck tape.
86cj74.2L is online now
post #348 of 446 Old 07-28-2013, 06:00 AM
sickcj978
Either way it was all disconnected and a lot was melted and I hope that it wasn't factory cause that's not rite there were wire connectors cut and bent around wire to make splices. I took it to work today and its running so much better after. Getting the timing right I just hope I didn't do any damage to the motor
post #349 of 446 Old 07-29-2013, 12:48 PM
Fletchlives85CJ
Newb here! I am Nuttering all over my new to me 85 CJ7, I do not see a purple wire at the ingnition module on my Jeep nor do I see one in my schematics. I do however see a light blue unused wire there. Is this the one I pair up with the orange and run to the disturbulator? BTW I have a good manual, and set of wiring schematics for 1984 4, and 6 cyl if anyone needs, I can send copies, or try to post them here...I am highly challenged when it comes to 'Putering...My rig is an 85 CJ 4.2l mostly stock...
Fletchlives85CJ is offline
post #350 of 446 Old 08-25-2013, 06:27 AM
83cjnash
1983 CJ7
Ok so let me get this straight. Does the nutter bypass eliminate all the wiring that has to do with the ECG? Thanks
83 CJ7, 258 ci, T176, 33x10.5 km2 stock axles with 2.73 ratio
83cjnash is offline
post #351 of 446 Old 12-11-2013, 12:22 PM
1949er
Just my .02 , after a heart valve transplamt on the carter BBD - 20% improvement - I decided to remove it's Pacemaker - the MCU - at the local
U - Pull It I secured a wire harness segment from a Fairmont with the correct plugs for the Dist. , coil & Ignition Module and extended them to 62" plug to plug with the wire to the coil a few inches longer then it was a plug in and done - MCU is bypassed - another Big Improvement . afterwards I removed the computer harness with most of the vac. switches and found the valve cover , only extra wire I added was from the flat 6 conductor weather-pac connector to the choke coil - 2 of them are 12v. keyed ign. , the manifold heater is on the eng. harness and still functions , when I spliced the wires I soldered them and covered with 2 layers os shrink tube & split loom cover , don't forget the dielectric grease on the plugs , my 86 cj7 purrs now .
1949er is offline
post #352 of 446 Old 12-11-2013, 03:04 PM
86cj74.2L
86cj74.2L's Avatar
Hope your duraspark lasts longer than Grammys did.
I did a half nutter. I let the mcu still operate the carb. I took control of the spark.
post #353 of 446 Old 12-11-2013, 04:18 PM
1949er
By putting it back to the way it was supposed to be wired ? , 2 of the 4 are spliced to bypass the MCU the other 2 just travel the harness , I've never had trouble with the Dura Spark system unless some FBN part has been replaced by a Parts Changer - A Mechanic figgures out what's wrong and doesn't just throw parts in till it runs .
1949er is offline
post #354 of 446 Old 12-11-2013, 06:02 PM
86cj74.2L
86cj74.2L's Avatar
Trust me I'm a mechanic. I don't throw parts.
Everything I do had to be bullet proof. If it isn't I would get a call from Grammy telling me her jeep won't or wouldn't start. Any mod I wanted to do had to work flawlessly by Monday morning.
I paralleled the orange and purple wires coming from the distributor and ran them to my MSD. I could probably remove the two vacuum switches (load sensing for timing) and two of the three vacuum solenoids the upstream and down stream air injection pumps) on the valve cover. But I didn't.
In my opinion the BBD and the MCU does a good job of controlling the fuel. The spark side to me had a lot to be desired.
I would drive it to California now, I trust it so much. In the beginning (I met my wife in 1998 and assumed the duties of CJ maintenance) not so much.
post #355 of 446 Old 12-11-2013, 10:47 PM
1949er
Well as a Retired Mechanic after working in pretty much all fields of repair for 45 yrs. when you take a controled unit and remove just one of many sensors or controling factors it can and will have an effect on the entire system , the computer controled BBD was a futile attempt to control smog even tho AMC had MPI on the 4.0 , the combustion chamber of the 258 is the main culprit as it is not efficent , the 4.0 is better and in conjunction with the MPI it does well , It seems to me if you take a carb and put a motor on it that is controled by several different components with ware factors as well as age and climate change it spells trouble , I'm building a non-stepper carter ( not much better ) for this motor and if it doesn't work it will get a Rochester 2gc.
1949er is offline
post #356 of 446 Old 12-12-2013, 03:31 AM
86cj74.2L
86cj74.2L's Avatar
It's been like this for long enough to know there are no issues with it.
When I had the stepper centered and unplugged the AF was ok below 40mph and lean above. Raising the needles to fatten up the AF above 40mph made it too rich for my liking below 40mph. So I hooked the stepper back up and woke up the MCU.
A few years later when I rebushed the baseplate I put my Fluke DVM on average and drove it around 8 miles and the times I recorded the averaging it averaged .49 to .51. Which is as good as any FI would do. I have at least 1 or two YouTube videos to prove it.
The needles out of a non-stepper probably would have had a better profile and solved my problem. However, I used the MCU and liked my results.
post #357 of 446 Old 12-20-2013, 12:50 PM
ElSid
New to me 84 CJ. I am in an EMISSIONS zone. Working on finding out if the pulse air works and was wondering if "Nuttering" would affect anything. This is a CA Jeep, though I live in Las Vegas. They check to make sure components are there (CAT, PUMP (should be fun to explain the pulse air), and fuel restrictor) and then tail the emissions. I am getting a new exhaust/cat since I do not trust a rusty 30 yr old unit. I was planing on doing the Nutter and Rush upgrades. Any feedback would be great. I prefer to eliminate the computer and ... in the future, maybe do a junkyard TBI.
ElSid is offline
post #358 of 446 Old 12-20-2013, 05:37 PM
86cj74.2L
86cj74.2L's Avatar
Did it ever have to pass emissions before you bought it?
post #359 of 446 Old 12-20-2013, 06:20 PM
ElSid
Yes. It was a CA car. It was on non-ops to avoid fees when I bought it. Now titled in NV, looking to register it
Sent from AutoGuide.com Free App
ElSid is offline
post #360 of 446 Old 12-20-2013, 07:34 PM
Centerfire
Originally Posted by ElSid View Post
New to me 84 CJ. I am in an EMISSIONS zone. Any feedback would be great.
How about registering as a "Classic Vehicle" and being exempt from emissions testing?
Vehicles registered with Classic Vehicle, Classic Rod or Old Timer license plates and driven 5,000 miles or less per year are exempt from emissions testing.
http://www.dmvnv.com/emission.htm#Classic
NRS 482.3816
A Nevada resident who owns a passenger car or light commercial vehicle (having a manufacturer’s rated carrying capacity of 1 ton or less), manufactured at least 25 years prior to the date of application, may apply for Classic Vehicle license plates
http://www.dmvnv.com/pdfforms/sp34.pdf
Centerfire is offline
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
What's a Nutter Bypass? ollietonk Jeep CJ Forum 11 04-05-2005 08:50 PM
