How to - Nutter Bypass - Page 14 - JeepForum.com
post #196 of 443 Old 11-11-2010, 05:12 PM
Mike Romain
Originally Posted by Chanse View Post
I have a 86 cj7 that will not start, I have replaced the ignition switch. Starter, starter solenoid, ignition module new battery cables. Does the computer have anything to do with ignition or does it just control the carburetor? If it does control the ignition in anyway then I will try the nutter bypass
Does your engine turn over?
Meanwhile, yes the computer controls the spark signal to the coil.
Mike Romain is offline
post #197 of 443 Old 11-11-2010, 08:42 PM
Chanse
No the engine does not turn over. I can cross the terminals on the starter solenoid and It will turn over and run but sometimes the starter will stay engaged when i do this. But nothing when I try to crank it with the key
Chanse is offline
post #198 of 443 Old 11-12-2010, 07:35 AM
OPlo
1987 YJ Wrangler
Originally Posted by Mike Romain View Post
Ditch the 4" vacuum line, it no longer functions and use that T for the distributor.
Some canisters are plumbed direct off this ported nipple on the valve cover side of the carb also, so if yours goes that way, leave it. other types of canisters can benefit from using the emissions port on the bottom front corner, most have that nipple capped.
thanks much - i did as you said with the 4" vac. left the other one in place. there is so much garbage running on the front side of the carb that i will have to push out of the way to get to the idle mix screws.
did the timing last night as well. worked out great. 1st time i'd ever done that. wasn't sure what the "notch" would look like. when i first hit the gun i didn't see it at all. it was buried below -2. not even visible. all good now.
on other odd thing. when i went to remove the reservoirs to get at the ignition module, the 1st bolt broke off in the fender well. so instead of going any further with that i just did the wiring to the ignition module from underneath. thankfully with the 33"s and a 3" BL (not ideal, i know) i can get to stuff without a lift.
still a bit confused on the carb adjustments. need to read up on that. looks like there is a metal shield on the front side of the carb i have to take off to get to the screws. true? it seems to be idling nice and steady at about 700 when warm. do i even need to mess with the carb? one of my wife's main complaints about he jeep is the smell. i have a magnaflow with no cat. would adjusting the idle mix help at all with that?
OPlo is offline
post #199 of 443 Old 01-08-2011, 09:21 PM
Joe203
I live in Beebe, AR. How can I contact you luckycheesehead??
Joe203 is offline
post #200 of 443 Old 01-09-2011, 06:45 AM
Mike Romain
You have solenoid side post connections or keyswitch issues.
Mike
post #201 of 443 Old 01-09-2011, 06:46 AM
Mike Romain
Haven`t heard him around lately, but then I haven`t been around much either.
Mike
post #202 of 443 Old 01-12-2011, 03:34 PM
Joe203
Does it make a difference if the stepper motor is unplugged or not? The Nutter article doesn't mention it but someone here said to leave it unplugged. I'm going to go with the 1/8 out adjustment for the needles.
Joe203 is offline
post #203 of 443 Old 01-12-2011, 03:40 PM
scrapman
Step #2 on the first post of this thread says to unplug it once you have the metering pins in the correct location and IT STAYS UNPLUGGED FOREVER.
You leave it unplugged because you don't want the computer moving the metering pins after you have them set correctly.
scrapman is offline
post #204 of 443 Old 01-12-2011, 05:30 PM
Joe203
I thought once the bypass was done the metering pins don't get signals to move from the computer. The oxygen sensor wouldn't have any effect either. Maybe I misunderstood.
Joe203 is offline
post #205 of 443 Old 01-13-2011, 08:10 PM
Joe203
If you wanted to run the distributor with manifold vacuum instead of "ported" vacuum would you just leave the distributor the way it is or connect it somewhere else? I read in other threads the manifold vacuum was better for advancing the timing.
Thanks to all for your help. I have learned a lot since getting the YJ on Dec. 1st.
I've just re-read this entire thread and answered most of the questions I had. I also see there are more than one opinion as to using ported verses manifold vacuum. I'll do what Mike says and use the ported.
Joe203 is offline
post #206 of 443 Old 01-20-2011, 07:04 AM
Mike Romain
The computer may still have a 'limp' mode that will set/move the pins.
Mike
post #207 of 443 Old 01-30-2011, 05:08 PM
BlackOpsPete
WOW! Did the Nutter today and it is, as you have said, a whole new vehicle! I still have a few adjustments to make. Sounds like I have a little detonation but it really runs great, way better than before. The idle dropped from 1200 to about 850, smooth, no missing or roughness. This is a good mod!
So any best advice on correcting the detonation? Retard the timing or open up the stepper needles? I have it closer to 1/4" rather than 1/8"...
BlackOpsPete is offline
post #208 of 443 Old 01-30-2011, 05:46 PM
Mike Romain
Timeing first, then lean the pins likely. You have it rich.
Mike
post #209 of 443 Old 02-01-2011, 12:21 PM
bvrshtr
I'm getting ready to do the Nutter on my 86. Only question I have (so far) - the PO put a manual choke on. Should I leave it alone? If I need to get rid of it, is it as simple as disconnect and it magically fixes itself or what?
Thanks!!
bvrshtr is offline
post #210 of 443 Old 02-01-2011, 12:43 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Thanks!!
You need a choke of some kind whether it's automatic or manual. If the PO installed a manual choke, then I'd leave it there and leave it connected assuming it's working correctly.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
What's a Nutter Bypass? ollietonk Jeep CJ Forum 11 04-05-2005 08:50 PM
