How to - Nutter Bypass - Page 11 - JeepForum.com
post #151 of 447 Old 04-07-2010, 01:38 PM
LoveableLaLa
Can someone tell this noob exactly what supplies and tools I need to do this?
TIA
LoveableLaLa is offline
post #152 of 447 Old 04-07-2010, 02:12 PM
crzdmnky
1978 CJ5
Needle nose plyers, and good timing light or a sensitive ear to how the engine is running, and two pieces of wire about 3ft in length. There should be a picture thread of this somewhere, here it is, hope this helps, if ya need any other help feel free to PM me, I should beable to guide you thru this pretty easily. And I am on all day till 11pm, because I sit at a job that doesnt require alot of demand.
http://www.jeepforum.com/forum/f12/p...bypass-476720/
crzdmnky is offline
post #153 of 447 Old 04-08-2010, 05:23 AM
Mike Romain
TIA
I use two new chunks of 16 ga. wire about 6' long twisted together for RF insulation to connect the module to the distributor without messing inside the Jeep harness.
I then use solder and weatherproof heatshrink to connect the wires at the distributor harness plug on the vehicle side of the harness so the distributor still keeps it's plug. At the module end, I use a male/female bullet connector soldered and crimped in place on the purple wire so when/if the module has to be changed it can still be unplugged and a quick crimp on bullet connector half will get the new module ready fast.
I solder the orange wire just before the plug at the module so the old orange gets cut out there. not up inside the harness near the computer like some do.
You will then need a small flat head screwdriver to set the carb mix screws and a timing light and I think it is a 1/2" box end wrench to set the timing up.
Mike
Mike Romain is offline
post #154 of 447 Old 04-14-2010, 01:45 AM
budello
1987 YJ Wrangler
Just do it. Very easy work. Now run very nice.
thank you guys
budello is offline
post #155 of 447 Old 04-29-2010, 12:43 PM
crsltman
1987 YJ Wrangler
WOW--anyone debating whether to do it or not? Do it!!! Fantastic!! been kicking it around for 2-3 years and after seeing this really easy to understand post, went ahead and what a difference--everything you've heard is true--thanks for the post and all the efforts that went in to it! 87YJ
crsltman is offline
post #156 of 447 Old 06-06-2010, 06:29 AM
CDFLIGHT
What a difference. I just did it to my 89 YJ because it would intermittently die. I did it to troubleshoot the microprocessor but will probably leave it that way. It is much smoother than it used to be. Thanks for the tech support and a great write-up. You guys saved me lots of money and time. Greatly appreciated.
CDFLIGHT is offline
post #157 of 447 Old 06-11-2010, 05:05 AM
Mike Romain
It was brought to my attention in another thread that if you want to keep the EGR working you might be able to get a bit more punch out of the engine by running the vacuum line to the EGR off the front bottom drivers side port on the BBD or the E port. On lots, this is capped on lots this was used. They made different flavors of EGR valves. This writeup says to use the S port which is OK for them, but a little more vacuum advance to the distributor may be had on some by using the E port.
Same for the Canister, most use a CTO so they don't turn on until the engine is warmed up, but some are direct from the S port. There are different flavors of chokes which can account for that.
Mike
post #158 of 447 Old 07-03-2010, 03:16 PM
jwill
I too, have some questions concerning the EGR hook up. Im getting ready to do the nutter bypass but i'm still uncertain where the egr connects after the nutter.
I have an '84, everything stock with a Weber 38. Also, 2 port CTO if that helps.
thanks
jwill is offline
post #159 of 447 Old 07-04-2010, 02:58 AM
BigOrange90YJ
thanks
I don't think you need to change the EGR. That is not part of the nutter.
Currently Jeepless, if you get too frustrated with yours I'll take it off your hands.
BigOrange90YJ is offline
post #160 of 447 Old 07-04-2010, 10:28 AM
IdahoJeeper
"Nuttering" helps but one last step has not been emphasized.
There is a thread out there about this but it needs to be included in this thread too. Apologies if it's in here.
The computer controlled ignitions, include a dizzy that has either 6.5 or 7.5* of mechanical advance. The computer adds more advance if it's required. When you bypass the computer (Nutter), you limit your mechanical advance to about half what it could be.
Pick up a dizzy for a '79 (non-computer) 258. The mechanical advance is 13.5 or 18* of mechanical advance. You'll get that 'snappy' throttle response. Search distributor swap for details on how to it
Did mine a couple weeks ago. Cost about $60 after core return from CarQuest.
'95 ZJ Laredo, 4.0L, Auto, 225K, Forest Grn
'98 ZJ Laredo, 4.0L, Auto, 210K, White
IdahoJeeper is offline
post #161 of 447 Old 07-04-2010, 11:59 AM
mcmud
1983 CJ8
Scott you have made a great point. As you've mentioned it should be included so here is a most revealing thread.
http://www.jeepforum.com/forum/f8/te...wiring-595104/
In it among other very interesting things the readers will find how to flip the advance head of the pre-computer dizzy and the reported advantages that you may find in using the TFI coil.
jwill, in that your 38DGS Weber is most likely fitted with only the "S" ported nipple and if you're intention is to use it for vacuum timing advance I suggest that you not connect it to the EGR in any fashion. Considering the bleed of the EGR it will cause the vacuum advance to suffer that amount of loss and that reduces the amount of vacuum timing advance.
While being an advocate of the use of the EGR I want to point out that the genuine Webers can be tuned so that the EGR is not so necessary.
This is a most opportune time and I suggest that you read up on using manifold vacuum as the advance source so that the 'S' port would be free to use as the emission control just as it was prior to your Weber install. Here is a thread that touches on that very subject. http://www.jeepforum.com/forum/f8/timing-1055680/
mcmud is offline
post #162 of 447 Old 07-04-2010, 02:39 PM
gmgreen
1983 CJ7
Stupid question here so take it easy. I have a 34 deg carb on my 83 CJ7. I just tried to unplug the computer to see what would happen. It would not start. Plugged in back in and all is good. Do I still need to do the wiring change? I want to get the computer and associated wires out.
gmgreen is offline
post #163 of 447 Old 07-04-2010, 03:41 PM
crzdmnky
1978 CJ5
You need to nutter it. Cut the orange and purple wires at your Ignition control module, and do the same to the wires coming out of the firewall on the opposite end of the engine bay, and use two long wires and connect them. This will bypass your computer.
Anyways, read the instructions and look at the pics, they helped me out when I did mine.
crzdmnky is offline
post #164 of 447 Old 07-04-2010, 04:09 PM
Mike Romain
I believe it is the other way around, the advance is in there on the computerized distributor and the computer retards it (knock sensor for one part) so you do still get the top end punch with the stock distributor.
Did it make a noticeable difference other than just changing worn parts for new? More punch? Curious...
Mike
post #165 of 447 Old 07-04-2010, 04:11 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Sounds like a job for the Nutter Bypass. Oh, wait, that's the original point of this thread
Without the computer, the ignition system isn't going to work correctly. The Nutter Bypass will take the computer out of the ignition system loop.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
Nutter Bypass... poppatello Jeep CJ Forum 1 06-27-2009 06:19 PM
nutter bypass bulljeeper Jeep CJ Forum 2 06-25-2007 02:13 PM
Nutter Bypass Trooper3385 Jeep CJ Forum 10 05-29-2007 02:08 PM
nutter bypass sailkid Jeep CJ Forum 1 05-24-2006 06:12 AM
What's a Nutter Bypass? ollietonk Jeep CJ Forum 11 04-05-2005 08:50 PM
