How Much Torque on Shackle Bolts? - JeepForum.com
post #1 of 17 Old 10-31-2009, 08:09 AM Thread Starter
Strings72
I'm puttting my suspension together for the last time. Currie didn't give me torque specs on there shackle bolts, How much do you think is enough?
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #2 of 17 Old 10-31-2009, 08:15 AM
-AC-
1977 CJ5
I'm pretty sure the spec for my CJ-5 is 20ft/lbs, of that helps any... I'd have to go look to be sure, but 100ft/lbs for the pivots and 20 for the shackles sticks in my head.
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #3 of 17 Old 10-31-2009, 08:15 AM
gmakra
Its like 35-45 Ft Lbs,you dont want to tighten them to tight so that you pinch the bushing. When you tighten the shackle bolt you want to be able to turn the bolt with slight pressure on the wrench.
If you torque the whole assembly too tight the ride will be very rough since the shackle cant not move with the flex of the suspension system.
gmakra is offline
post #4 of 17 Old 10-31-2009, 08:22 AM
JeepHammer
Running On Empty...
1973 CJ5
There is no set torque on shackle bolts, mostly because you are supposed to use a LOCKING NUT...
You simply tighten until you see 'Rubber' take up a little, and leave them alone.
Over tighten, and you smash the bushings and the get cut through really easily.
Under tighten, and you will have shackles/bolts moving around letting the suspension move around when you make steering corrections.
Snug LOCK NUTS up until you see the 'Rubber'
(rubber, urithane, or what ever your bushings are made of)
bulge a little, and you are done. Nothing to it!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 17 Old 10-31-2009, 08:36 AM
-AC-
1977 CJ5
I just got off my lazy butt, went out to the shop, and checked my Chilton's. They say 24lbs for the shackel nuts and 100lbs for the pivot bolts, 1977-86. Would I take the word of a lot of experienced Jeep people over the guys at Chilton's? Every time...
But, for what it's worth, that's what the book says.
-AC- is offline
post #6 of 17 Old 10-31-2009, 08:43 AM Thread Starter
Strings72
thanks guys I really dont want a rough ride
strings
Check out my build:
post #7 of 17 Old 10-31-2009, 10:19 AM
Mike Romain
The stock ones came with stainless sleeves in them so when the lock nut came up, it came up hard on this sleeve. If you don't have replacement sleeves or haven't dug out the originals, then as JeepHammer says, be gentle on them. I had a shop change mine, for issues like that and they had to torch the rubbers to get the old sleeves out.
Mike
Mike Romain is offline
post #8 of 17 Old 10-31-2009, 10:30 AM
JeepHammer
Running On Empty...
1973 CJ5
Mike is correct, and what I told you is for rubber or urithane or whatever 'Mushroom Head' bushings, not factory bushings...
Factory bushings have spacer sleeves to keep you from screwing up too bad!
Just crank down until the mushroom heads start to 'Puff Up' or get smashed a little,
AND STOP!
If you keep cranking down to factory specs, you WILL cut the heads off the bushings.
You might not believe this, but this is what I handle every day at work....
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #9 of 17 Old 10-31-2009, 11:30 AM Thread Starter
Strings72
Where Do you work that uses all those poly bushings?
Check out my build:
post #10 of 17 Old 10-31-2009, 02:29 PM
JeepHammer
Running On Empty...
1973 CJ5
Air suspension company for hot rods...
We use air springs (air 'bags') instead of steel springs for better ride, adjustable ride, adjustable height and we race the cars very successfully.
Usually, if you have a race car, you have a very stiff suspension and harsh ride,
With air springs, you change the air pressure and you can go from highway cruising like a Cadillac or Lincoln to a flat out race car simply by changing the air pressure.
You can also change the ride height,
Down low and fast for racing, up higher for highway cruising, and way up high for speed bumps, parking curbs, giant pot holes, ect.
Looks something like this,
We also make our own shocks since there just isn't anything on the market that will give us the adjustment we want...
Sway bars are an issue with these old, large body cars, so we make our own sway bars also...
And we make all our own 4 link, 3 link and A-arms in house...
And the company cars are pretty cool! Noting like doing your daily commuting in a vintage muscle car that has been turned into a SUPER Muscle Car!
It's a FUN place to work!
Always a good day when the boss encourages you to leave 1/8 mile of black marks or pull 1 G. on the skid pad just to see if anything is going to fall off!
If you live anywhere around Las Vegas, the SEMA show starts on the 4-Nov-09 and the road show crew will be there with the best products of ours from the past, and the new stuff for next year on display...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #11 of 17 Old 10-31-2009, 04:47 PM
-AC-
1977 CJ5
Ummm... My company car is a Dodge Minivan...
Am I cool too?
Didn't think so...
-AC- is offline
post #12 of 17 Old 11-01-2009, 06:56 AM
JeepHammer
Running On Empty...
1973 CJ5
I don't drive the GSX anymore, it's a $100K SMC, Now he's got me driving a '66 Impala we are working on a kit for.
I actually like the Impala better! More room for my LARGE BUTT!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #13 of 17 Old 11-01-2009, 11:23 AM Thread Starter
Strings72
Wow!!!! You guys hiring hahaha
Check out my build:
post #14 of 17 Old 11-01-2009, 12:43 PM
jscherb
According to the Jeep factory service manual, section J (Suspension), page J-2, proper torque for spring shackle nuts is 24 ft-lbs.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #15 of 17 Old 11-01-2009, 01:57 PM
JeepHammer
Running On Empty...
1973 CJ5
Again, if you are running factory bushings with sleeves, the about 24 Ft.lb. is correct.
For aftermarket bushings with 'Mushroom' heads, you should bulge the bushings a little, and leave things alone.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
Torque on u-bolts doughocker Jeep CJ Forum 2 01-16-2009 11:10 PM
Shackle Bolts slacker92104 Jeep CJ Forum 3 11-01-2007 11:09 AM
greasable shackle bolts wm69 Jeep CJ Forum 2 11-18-2006 03:43 PM
shackle nut torque specs wwhitby Jeep CJ Forum 1 10-01-2006 10:05 AM
stock shackle bolts??? randyscj Jeep CJ Forum 10 04-16-2005 06:46 PM
