How much lift for a particular tire size? - JeepForum.com
post #1 of 7 Old 04-01-2007, 06:32 PM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
I once saw a chart that showed how much lift that you need to run a particular tire size. I'm trying to figure out what I need to get my 35's on.
supraman1990 is offline
post #2 of 7 Old 04-01-2007, 07:37 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Was it the one in JP Magazine about 1-1/2 or 2 years ago?
http://www.jpmagazine.com/techarticl.../photo_03.html
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 7 Old 04-01-2007, 07:58 PM Thread Starter
supraman1990
1980 CJ5
Yeah, that looks like it. Thanks. Maybe a mod could sticky this or something? Similar to what the FAQ has in the YJ section. I know it would probably cut down on some questions.
post #4 of 7 Old 04-01-2007, 08:31 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I fit 35's with a 4'' lift and 3/4'' shackles
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #5 of 7 Old 04-01-2007, 10:44 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Another thing to consider is how tall a particular brand's tire is. My friend's CJ has 35's on it that are barely 34's.
My old 33's only were 31's in reality, but my new MT Baja MTZ's are supposed to be 32.9". Sitting uninflated next to the old ones inflated, the MTZ's are significantly taller.
So make sure your tire is really what it says it is....just because it says 33.12.50 on the side doesn't mean it's really that size.
Goes for car tires, too. I remember my old Trans Am..I used to burn the rears off on a regular basis. My dad owned a body shop/tire store, so I just kept used take-offs on the rear. I used 275/60/15's, and there was a drastic difference in the size depending on manufacturer. I had one set that actually rubbed, and another that barely filled the wheelwell up.
Pacfanweb is offline
post #6 of 7 Old 04-03-2007, 08:48 PM
bbaxter51
1979 CJ5
a 4" lift will get you there without a problem.
bbaxter51 is offline
post #7 of 7 Old 04-03-2007, 09:28 PM
mxg342
mxg342's Avatar
I'm running 36" Iroks (36.9") with 4" lift and TJ flares. I do however rub a little.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
Need Advice, lift, no lift, tire size, wheel spacers??? darwood112 Jeep CJ Forum 3 03-25-2009 12:55 PM
wheel rim size vs. tire size... hex Jeep CJ Forum 2 03-11-2009 10:10 AM
Max tire size on factory tire carrier SilverRubiSC Jeep CJ Forum 14 03-06-2009 08:46 AM
Rim Size vs. Tire Size Daniel W Jeep CJ Forum 11 12-17-2004 05:32 AM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 09:38 PM
