How much height can i lose by airing down? - JeepForum.com
post #1 of 4 Old 07-03-2013, 10:20 PM Thread Starter
83vert
1982 CJ7
I'm looking to put my new tires on but I'm afraid that they might make the jeep to tall to get into the garage. If I air down how much lower will the jeep sit? The tires are 34.5" and I have the rubicon 4.5" lift
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #2 of 4 Old 07-03-2013, 10:30 PM
skizriz
1978 CJ7
Probably not much unless you let almost all of it out. I air down to 8 psi when I go wheeling, with no noticeable bulge unless I plant a tire against something.
It would really suck to have to air up the tires every day.
I clear my garage door by less than 1". I could crank the door springs up tighter and gain another inch or so if I had to.
skizriz is online now
post #3 of 4 Old 07-03-2013, 10:39 PM Thread Starter
83vert
1982 CJ7
I think ill make it but it would suck if the jeep wasn't finished and I couldn't get it back in the garage.
I am in deep
83vert is offline
post #4 of 4 Old 07-03-2013, 11:39 PM
lucdog
1980 CJ5
If you have a door opener adjust it so the door opens further.
Wether you have a opener or not, adjusting the springs may not raise the door enough. The point of the springs be they torsion ( above the door, on the header) or the old style springs along the top rail, is so the door is balanced. Meaning if the door is opened 1/2 way the door will stay where it stopped.
If your spring(s) are the torsion style, and you have never worked on them, I strongly advise NOT adjusting them yourself.
I personally know 2 people who were off work because of injuries from trying this.
I do know the proper way to adjust this type of spring, and have done it a number of times.
I have a 7' garage door, my SOA CJ on 36" tires fits under my door, if I disconnect the opener and push the door up. A 2x4 is used to hold it up far enough. ( between the header and door)
My other CJ with 35" tires and 4" of lift fits thru the door without disconnecting the opener.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
