How many speeds on a dana 20 transfer case? - JeepForum.com
post #1 of 4 Old 11-06-2002, 05:30 PM Thread Starter
jeepin cj-5
Does the dana 20 only have 2hi and 4hi or is there a 4hi and 4lo? THis past weekend i was messing with the handle trying to find all the settings or gears and i could get it in 2hi and 4 wheel but i fihgured like most others there must be a 4 lo and i messeed and messed and ended up breaking a bolt in the linkage. SO is 2 hi and 4 hi all the dane 20 has?
jeepin cj-5 is offline
post #2 of 4 Old 11-06-2002, 10:54 PM
CSP
Yes there is a 4 low.
Shifting pattern:
4HI
2HI
Neutral
4LO
Sometimes with many Dana 20's the linkage can be worn to the point where you can actually engage 2LO between neutral and 4LO. If you don't like that you can add AN washers to the pins that hold the linkage together and remove the slop that allows this. Personally I like it in mine until I forget to slide it all the way back into 4LO when I really need it.
CSP is offline
post #3 of 4 Old 11-06-2002, 11:05 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
D20's have a four low. Try pumping the cluch while attempting to shift. Sometimes the gears won't line up making it impossable to shift. It is possable that the shift rail is bent or the fork has come loose. You might have to drop the inspection cover and eyeball the rail to see if it is moving.
jeepdaddy2000 is offline
post #4 of 4 Old 11-08-2002, 10:08 PM Thread Starter
jeepin cj-5
Thanks for the help. I ended up finding it> The problem was that my shift handle was getting caught up in the mount so i wasnt able to shift to nuetral or 4lo.
Dana 20 Transfer Case I.D. dreski1 Jeep CJ Forum 4 11-23-2009 10:24 AM
Dana 300 Transfer Case kuhndogs Jeep CJ Forum 3 01-19-2009 05:59 PM
dana 20 transfer case. Tell me what you know sail78385 Jeep CJ Forum 4 07-19-2008 08:47 PM
Dana 20 Transfer case Scott 77CJ Jeep CJ Forum 5 08-03-2007 10:51 AM
